Originally posted by Martowski Hi all,
Just curious if you have found what AFC settings work best with the KP when shooting gymnastics? Of course, typical indoor sports stuff at about 20 yards distance. I'm shooting my KP with a Tamron 70-200 1:2.8 and having issues with the AFC keeping up.
Thanks!
You'll probably need to set the "Hold AF Status", p59 in the manual, to Low or Off, but the camera is then relying on you to keep the subject matter within the focussing area so it doesn't "lock" onto the background.
If you give the camera too many focussing points to choose from there's a better chance that the "wrong" focus point will be chosen, so I'd suggest sticking to single-point a/f continuous and concentrate on keeping the subject under the focussing point in the viewfinder.
I use half-button-press of the shutter button for focus tracking, mostly 'cos that's what I'm used to, but there is valid argument for using "back-button-focussing" in this sort of scenario, which may take a little practice but many seem to swear by.
If the lighting is good enough and/or you're not too sensitive to high-ISO noise, stopping down by a couple of steps will give a bit more depth of field to help mask slight focussing errors, but if the ISO gets too high you'll have the noise-removal cycle slowing you down, so there may be compromises to be made.
As with much action photography, a modicum of practice will pay dividends, so take any opportunity to take pictures of anything active to become familiar with the capabilities of the camera … which are extensive!
If you've not applied the latest firmware update, my limited experience (before upgrading to my K-3iii) was that the follow-focus capabilities of the KP were improved, so that would be high on my list of priorities
Good luck.
PS :- Once you find a combination of settings that suit you, save them in a User Mode, then you can go back to them immediately without having to fiddle about
Reason: afterthought
