Originally posted by UncleVanya Why is shake reduction off with electronic shutter? I’m struggling to understand this.
ES doesn't allow for the anti-aliasing simulator either. Apparently it's due to the rolling shutter, the movement of the sensor for SR would cause distortion.
This does, however, raise a question regarding front/rear curtain on the mechanical shutter: the travel speed vs slit size can cause rolling shutter distortion... BUT - under the same circumstances, the ES is much more susceptible to it. When I look into it seems that the ES row scanning rate should be roughly equivalent to the travel speed of the shutter in MS mode.... AH! The difference is that ES reads one row at a time - "exposing" one row at a time - while the mechanical shutter exposes multiple rows on the sensor simultaneously (at a rate determined by the window size, and shutter travel rate - window size being the size of the gap between the leading and trailing curtains during shutter release).
In ES each row of the sensor is read individually, so you capture each row in beautifully crisp detail - think "line scanner". With a mechanical shutter, even though the shutter moves across each row of pixels, it is exposing many neighbouring rows of pixels - so each row captures a blurry afterimage where the ES would have captured only a single row at a time...
In other words...
IF that explanation is correct, under a particular circumstance where ES is prone to rolling shutter distortion, MS would result in a motion blur. Huh. I'll need to test this and see if this explanation is correct!
Originally posted by kypfer ...
One specific scenario quoted by Pentax where the electronic shutter comes into it's own is for wide aperture (shallow depth of field) work in bright light, anything from outdoor portraits to flowers in bright sunlight, where the subject is reasonably stationary and you don't want bother with an ND filter.
When using the viewfinder the mechanical shutter is still utilised, albeit not for controlling the exposure, also the mirror operates, so no great noise advantage there.
Oooh! I hadn't heard of that particular advantage! I'll add that to the list of scenario-specific usages
Good note on the sound as well - though, to be honest, beside the K-50, the shutter (and mirror) on the KP are practically silent! Sure, in a quiet room it'd be noisy in comparison, but in my firsts field test (I took it to a field and tested it
) it was refreshingly quiet. I didn't even think my K-50 was that loud until I got this!
Originally posted by clackers Be very careful, CP.
The mirror still clicks up and down so there's that noise. Rolling shutter means moving objects distort, and you can't use flash at all. Artificial lighting will look weird at different shutter speeds in different frames - banding, etc. Shake Reduction is turned off, too.
So, you really have to weigh up the current shooting situation.
Landscapes from a tripod? Sure. Everything else? Maybe!
BANDING! Yes I meant to mention that in the list of downsides.
Many thanks folks! That's cleared things up a lot for me - much appreciated!
