Originally posted by Wingincamera I am thinking about using one of my KP's for Infrared Photography. Would this good camera for infrared? If I do this, I will probably use an infrared filter first before making any physical changes to the camera. I also have a KS-2 and a K1000 film camera that is unused,
The KP, as with all Pentax cameras with CMOS sensors, will have limited sensitivity in the infra-red.
An R72 filter, as mentioned by Steve above, is about as "dark" as you can reasonably go and retain anything like "sensible" exposure times.
The KS-2 has the same limitations, unmodified.
For a "better" effect, IMHO, you might be advised to look for one of the older (6 or 10 M'pixel) cameras with their CCD sensors. These have much greater sensitivity to infra-red, unmodified, but unfortunately don't have the advantage of LiveView, though most of them have Digital Preview … quite important when the filter fitted to the lens is so dark you can't see anything through it
Taken with my unmodified *istDL2 and a Lee 87 filter
