Originally posted by Not a Number If the KP has MTP mode for USB settings you might try it on your PC provided its Win10 or 11. I'm not sure if the iPad supports MTP. If that does't work the USB port on the KP might be faulty. Test the cables on some other USB device to make sure they work.
Yes, that I'll do and report then.
Just collected some experience with
AutoFocus Fine Adjustment. Works with legacy lenses only with "Apply All". Probably because legacy K-Lenses do not have some kind of personality like modern e.g. DA-Lenses. So I made Fine Adjustment "Apply All" for my Pentax SMCs A Macro 1:4/200 ED. This adjustment of +5 luckily also fits my K 1:2.8/105 and probably the other less critical lenses also.
And an observation on "Preview" with histogram, mentioned above. That does not work with "M.UP" mirror up, multi exposure and "INT" intervall shooting.
