12-29-2017, 08:46 AM   #1
Mikesul's Avatar
Bluetooth found
Theta V connect with WiFi just fine but when I try to run the Android Theta app the app just keeps searching. the phone bluetooth app does not detect the theta. The phone bluetooth is very stable. I have it connected to several cameras and watches without difficulty. has anyone else had this problem? I keep expecting it to be something I have missed but I have run out of ideas. I have tried running both the Theta app and the Theta S app without results. the wifi connection shows but no bluetooth. Thanks for any suggestions.
12-29-2017, 08:57 AM   #2
photoptimist's Avatar
Is there any chance that bluetooth is turned off on the Theta?
Is there any chance that your Theta has already been paired with some other device?
12-29-2017, 09:06 AM   #3
Mikesul's Avatar
I suspect the second option you propose may be true. I have followed the instructions to reset but that did not fix it. Any idea how it could be unpaired without connection? I thought the reset operaation would do that but it didn't.
12-29-2017, 09:11 AM   #4
I don't have a Theta. Is there anything in the manual about putting the Theta in pairing mode? Some devices require a magic button dance (e.g., hold-a-button-2-seconds-then-double-click) to get them ready to pair.
12-29-2017, 09:37 AM   #5
Mikesul's Avatar
The procedure is to first connect to wifi and then to connect to the Theta bluetooth with the phone bluetooth utility. That would normally show the Theta as an available device but all it shows is several UI MAC addresses none of which will pair. The Theta apps just go to the phone wifi connection page when you try to connect. There is a wifi connection but on its own it does nothing. There is a UI
01-03-2018, 06:31 PM   #6
Mikesul's Avatar
Update
The problem may not be with the Theta. It may be something with the phone or Android version. I had no trouble connecting to an old Dell Android tablet. I will test with my wife's phone.
01-06-2018, 02:28 PM   #7
Mikesul's Avatar
False alarm!
I tried the Theta with my wife's phone and it connected without issue. I then tried again with my phone but left Bluetooth off on the phone until i had the wife connection. it hooked up as expected and works fine. Sorry for the unnecessary "problem" report. It was good for Ricoh, however, because I ordered another one from B&H in case I could not get the first to work. I had planned to return one of them when I had one working but I think I will keep both for now.
360, app, bluetooth, phone, ricoh theta, spherical, theta, wifi
Is there a Bluetooth Shutter trigger for Pentax lazarustx Pentax K-1 & K-1 II 25 12-21-2017 02:03 PM
Bluetooth, why is it so difficult? hks_kansei General Talk 8 10-11-2015 10:51 PM
Bluetooth radio? larryinlc General Talk 6 01-12-2014 04:10 PM
When do we get built-in GPS, wifi, bluetooth, and cellular data LTE? dmytty Pentax DSLR Discussion 116 12-18-2012 02:04 AM
May 1st, 2012 A Day Without the 99% No Work No School No Housework No Shopping jogiba General Talk 4 05-02-2012 02:48 AM
All times are GMT -7. The time now is 10:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
