07-20-2019, 03:10 AM   #1
deus ursus's Avatar
Theta SC won't power on
I bought a new-in-box Theta SC off a seller on 'the internet', charged it via a mobile phone charger from a wall socket with the cable that came with the camera. It's fully charged, but still will not power on when I push the power button.
The instruction manual says it should be charged via a PC. Might I have destroyed the battery when charging it directly from a wall socket?
07-20-2019, 04:40 AM   #2
Banned
Delete this message and send it back for refund....
07-20-2019, 04:49 AM - 1 Like   #3
D1N0's Avatar
A battery won't take more power than it needs while charging so a wall charger shouldn't harm it.
07-20-2019, 10:00 AM   #4
deus ursus's Avatar
That's what I thought as well. It's worse to charge it too slowly, right?
07-20-2019, 11:39 AM   #5
Did the power button on the side of the camera light up while you were charging it? If not, then perhaps there's a loose connection somewhere.
My observation has been that the Theta is a little bit picky when it comes to cables. If one doesn't work, try another.
I have charged mine using both a wall charger and a PC, so that shouldn't be a problem. I'm not sure if newer 25W+ chargers would break the camera, but I doubt it since USB is a standard, after all.
07-20-2019, 03:36 PM   #6
deus ursus's Avatar
It did light up, it seemed to charge properly.
I might try another cable, and see if that'll work better. Thank you for your help!
360, power, ricoh theta, sc, sc won't power, socket, spherical, theta, theta sc, wall
Theta SC astro sortie SunValley Ricoh Theta 360° Cameras 2 05-17-2019 06:41 PM
Theta SC settings for 360° photos/videos mhoule418 Ricoh Theta 360° Cameras 6 11-21-2018 06:31 AM
RICOH THETA SC Type HATSUNE MIKU Released OoKU Pentax News and Rumors 31 11-24-2017 11:06 PM
Theta SC - $196.95 (lowest price to date) Adam Pentax Price Watch 12 07-02-2017 04:23 PM
Ricoh Theta SC camera specifications leaked online(No 4K) OoKU Pentax News and Rumors 20 10-23-2016 11:45 AM
All times are GMT -7. The time now is 11:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
