4 Days Ago   #1
How do you protect your Theta Camera ?
The Theta camera's are generally well built. They are usually made of a magnesium metal that feels solid enough, but does not protect it from rain, heat, or drops. I should know, my Theta Z dropped while sitting on a Monopod when a strong breeze suddenly passed by knocking the whole thing to hard cement. The camera went dead for about 10 minutes, but I was able to revive it. unfortunately I noticed that after the fall, all my scans had ugly black streaks in them.
Richo is not exactly famous for speedy repair work , but luckilly my company said they will send me a replacement while the camera is being repaired. With that said, I began looking for protection cases for the Theta Z, but they pale in comparison to the protection cases for iPhones. Richo sells a protective case calle the TH3, but its made from plastic that I heard easily scratches, degrades the image a little bit and is quite expensive. I was thinking about just wrapping up the camera up in some type of rubbery tape so if and when it hits the ground it would just bounce off. Anybody has any ideas ?
4 Days Ago - 1 Like   #2
$65 seems cheap. Risk/reward. Yes, anything in front of a lens can degrade an image. Would your alt method impede camera functions? Would it create (over)heat concerns? Assure that if/when camera makes use of that's the only area allowed to impact? Seems the problem lies in operating with a monopod in conditions not favorable to monopod use, and that you solve simply with weight, ground screw/spike, or more legs.
3 Days Ago   #3
Pentaxian At Large
robgski's Avatar
As the others mentioned, get a better monopod, or a spiked monopod whenever situation allows. IF there is still risk, get the cover Ricoh makes and see if the image is truly degraded.
It is tough because of the 180 degree plus FOV the Theta allows. It's one of the only downsides to using the Theta, IMO.
3 Days Ago - 1 Like   #4
QuoteOriginally posted by robgski Quote
So far I found this "protective" case for the Z1 on ebay: Silicon Protective Case Silicon Protective Silicone Case with Lens Cover Shell for Ricoh Theta Z1 V8L0 | eBay Does not look that protective, but I was thinking that maybe I could wrap some type of rubberirzed tape arround the perimeter of the Case such as this: https://rubbersheetwarehouse.com/products/neoprene-rubber-strips-60a-medium-...nt=21540356803
Usually I use a Light Stand with a much wider footprint when I'm outside and the Monopod with a much smaller foot print when I'm inside. That day however, I could not get the RICOH TE-2 Extension Adapter Off the Monopod so I could switch to the Light Stand no matter how hard I tried. It was a breezy day, but I would not call it windy. I set up the Theta Z1 on the Monopod since I had no choice. I hid behind the bushes so I would not be seen on the Scans. Then I heard a loud "WAPP". The camera had hit the floor !.
360, camera, protection, richo, ricoh theta, spherical, theta, theta camera
Your vehicle: what do you have, why do you like it, and what do you not like? Auzzie-Phoenix General Talk 2809 01-22-2023 10:33 PM
Thematic Theta 360 images - post your Theta images here! RobG Mini-Challenges, Games, and Photo Stories 3 11-30-2019 05:19 AM
How do you protect yourself and your gear when outdoors in odd times KatPal General Photography 100 01-31-2016 05:26 PM
How do you protect your camera from the elements? redeleon Pentax DSLR Discussion 16 04-11-2010 07:08 PM
How do you guys protect your camera? greenboy Pentax DSLR Discussion 49 04-15-2009 01:09 PM
All times are GMT -7. The time now is 01:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
