Originally posted by gatorguy While that $6K Nikon D6 allows for somewhat automated lens adjustments (tho manual is sometimes needed) even they have limits when it comes to a zoom lens.The camera can store two fine-tuning values for a zoom: one for use when all the way out and another zoomed all the way in.
Okay, yes, thank you for reminding me about the details of Nikon's implementation. My assumption is that this provides merely a linear interpolation between these endpoints. That's pure speculation, and I have not handled any of the Nikon camera with this tech. I wouldn't be surprised if this adequately corrects all but the most egregious cases of F/B focus throughout the zoom range.
An ideal system would let you define the amount of correction at each end of the zoom range (or even automate this process for you), and then apply a polynomial function (curve) to set the amount of correction at every focal length based on the known optical properties of the lens design.
If this were done, then there would be almost zero advantage to an MILC design (other than it would probably be cheaper and easier to manufacture). Some will still prefer the compactness of a MILC design, but I need any camera I handle to have a beefy grip so that I can confidently hold and control the camera with a heavy lens attached. Incidentally, though not a MILC, this was my main gripe with the KP, and I will probably never own one for that fact alone (yes, I am aware of interchangeable grips, but resent having to buy an accessory just to be able to hold the camera).
Originally posted by stevebrot Agreed...the Nikon approach make it much more convenient and I wish the K-3iii had this tech. The patent will probably expire one of these days.
The patent must be pretty broad in scope to prevent Ricoh from developing a similar technology.
Originally posted by Rondec It feels like this sort of tech should be relatively easy to implement with a firmware tweak.
(I guess the question would have more to do if Nikon has patented their particular implementation).
Yes, I assume that any camera, at least any camera that has fine focus adjustment capibility, can have this implemented in a theoretical firmware update.
