04-29-2021, 06:11 PM   #31
Otis Memorial Pentaxian
QuoteOriginally posted by Kobie Quote
The AF points themselves in AF.S don't light up, the whole viewfinder does to indicate "in focus".
The manual says the green hexagon is still there for focus confirm, but not showing the active focus point is not acceptable. What do you see when working the joystick?
04-29-2021, 07:02 PM   #32
Kobie's Avatar
When you move the joystick or change any AF mode, the viewfinder lights up only to tell you know you've made a change.
04-29-2021, 07:41 PM   #33
By any chance did you customize your viewfinder display and maybe turn AF points off?
If this was a help-me thread someone would have suggested a factory reset and someone else might have suggested the firmware update v1.01.
04-29-2021, 07:46 PM   #34
Kobie's Avatar
The only viewfinder AF light related option is "viewfinder light>auto>on>off".
I'm not the only one, EVERY person with a K-3 III has the same experience.
It works fine in AF.S, it's only AF.C where it doesn't work and no matter which AF mode you pick, the AF points themselves do not light up. In AF.S (just like the K-1/II) the viewfinder briefly lights up when focus is confirmed which will also illuminate the AF point overlay.
All of that vanishes in AF.C.
And yes, I reset, did the new firmware. I've confirmed that this is just how the camera is after asking others to check theirs.
04-29-2021, 07:53 PM - 1 Like   #35
Sorry...I didn't see the poll.
OK...that makes more sense. I believe misread a few of the comments.
You would at least think they would give you an indicator indicating tracking, if not the actual point.
04-29-2021, 07:57 PM   #36
Kobie's Avatar
Well, technically they do. Thin black squares which doesn't help when shooting a dark subject or in dark environments. You can't make out the AF point locations so you loose what's happening with the tracking.
---------- Post added 04-29-21 at 11:09 PM ----------
Here is what I'm talking about.
First is AF.C, then I switch to AF.S.
04-29-2021, 10:21 PM   #37
Not A Number explains how this works pretty good here:
Initial Reaction: K-3 III - Page 9 - PentaxForums.com
.. I shoot a lot of birds in flight and I find when you're out on the wilderness surrounded by trees as the background, you just can't see the AF points so you really have no clue what the camera focused on. Was it the bird, or the tree, or the branches of the tree next to the bird? ..
I think the solution is to let the user flash the viewer light to check the focus point with one of the buttons.
04-30-2021, 12:25 AM - 1 Like   #38
or just have a toggle in the settings to keep it on/off/on-demand via button as Tesla said above - either way seems just a software fix
af, af.c, aps-c, comments, dslr, firmware update v1.01, focus, indicator, k-3 iii, k-3 mark 3, k-3iii firmware, light, poll, sense, steve, viewfinder
k1000 light meter is effected by light entering the viewfinder pixmeister Troubleshooting and Beginner Help 16 10-11-2020 03:40 PM
Changing aperture doesn't darken viewfinder image? Moropo Troubleshooting and Beginner Help 11 12-01-2014 02:38 PM
Viewfinder doesn't match final image Tomzee93 Pentax K-5 & K-5 II 4 06-11-2011 12:15 AM
viewfinder doesn't match image - confused MollyM Pentax DSLR Discussion 14 10-12-2009 07:30 AM
Viewfinder doesn't show the full picture?? Peter Zack Pentax DSLR Discussion 15 11-30-2007 08:55 PM
All times are GMT -7. The time now is 11:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
