04-29-2021, 07:22 AM - 1 Like   #31
QuoteOriginally posted by FozzFoster Quote
I've never owned a K-3 or a K-1 (only handled in-store or acquaintances) - good to know that the card slots are swapped!
From my K-3 III only perspective, the current order of the cards seems to make the most sense to me - so I'm glad they changed it :P
Agreed.
If shooting RAW+ that's the card most likely needing a swap-out, and the easiest to access with my SpiderPro strap on the camera. BTW, I wouldn't own a DSLR without one installed. They are just soooo secure and comfortable in hand, I've never had to worry about dropping mine. SpiderPro handstraps are commonly found on sale at half the retail price.
This programming made possible by me. Now back to our regularly scheduled discussion.
04-29-2021, 07:43 AM   #32
QuoteOriginally posted by cats_five Quote
Ah yes. The page is long enough it was off the bottom of the screen... Doh! Thanks!
And no problems updating the firmware.
04-29-2021, 08:13 AM - 1 Like   #33
QuoteOriginally posted by fifescapes Quote
Bragger.
04-29-2021, 08:24 AM - 1 Like   #34
Larrymc's Avatar
QuoteOriginally posted by gatorguy Quote
I was just logging in to ask some of my fellow Pentaxians for an assist. I tried at least a dozen times to update the firmware. Every step was done properly yet holding menu while booting resulted in a normal startup. Over and over. Trying another freshly formated card with the bin file in the root was the same. Nada. Was my camera defective??
So midway thru my first sentence for this post I thought I'd triple-check the file. Dang if i didn't not only once BUT TWICE download and extract the ....
K3 II file. I'm such a doofus.
And only two beers!
The camera is smarter than you!!!:
04-29-2021, 03:21 PM   #35
mlt
Just make sure when you download the next firmware update to make sure your computer hasnít added a sequence number if it sees the previous file in your download directory. Always seems to forget to delete the old copies first and end up having to rename the file.
04-29-2021, 04:32 PM   #36
clackers's Avatar
QuoteOriginally posted by bpcarlson Quote
Slot one in the K3 iii is where #2 is in the other cameras. :-)
About time they fixed this!
Another thing to like about the K-13 III. I assume the K-1 III and the 645z II (if the Excel spreadsheet still says an ROI is worth it for medium format) will continue this.
04-29-2021, 05:40 PM - 1 Like   #37
SimplyCreativePhotography's Avatar
I'd update immediately. No point shooting with a firmware version Ricoh are unhappy with!
The problem will be that I suspect I will need to drive to the local courier location to pick it up if I don't happen to be at home at the time they come. I'm getting my new SD cards on the same trip. I guess I could download the new firmware on an old SD card and have it ready but you should never put new wine in old wineskins (or something like that) so I suspect the shots I take on my way home will be "adequate".
04-29-2021, 07:28 PM - 1 Like   #38
mlt
QuoteOriginally posted by SimplyCreativePhotography Quote
As long as the “older” card has been formatted in the new K3iii there shouldn’t be any issues unless previously had issues.
04-29-2021, 10:42 PM   #39
Latest PENTAX K-3 Mark III Firmware Update : Software Downloads | RICOH IMAGING
Thank you for using a PENTAX K-3 Mark III digital camera.
RICOH IMAGING COMPANY, LTD. wishes to announce the release of Firmware Update Software Version 1.01 for PENTAX K-3 Mark III.
Firmware in this document is the software that runs inside digital cameras.
Changes to V1.01
  • Improved stability of performance when battery power is low condition.
  • Corrected – In rare cases, images are not recorded correctly when shooting continuously in RAW format.
  • Improved stability for general performance.
Caution
  • Only PENTAX K-3 Mark III users are permitted to download the firmware update.
PENTAX Firmware Update Software for K-3 Mark III
Name: PENTAX Firmware Update Software for PENTAX K-3 Mark III
Registered name: K3III_v101.zip (zip type 30,554 Kbytes)
Applied product: PENTAX K-3 Mark III
To check the version number, press the menu button and select [Firmware Info/Options] in the [Set-up 6] menu then press the four-way controller right.
Updated firmware file: For Mac and windows : zip type
Release date: 2021/04/28
Copy right: RICOH IMAGING COMPANY, LTD.
Done!
I am still getting used to this new menu system. Coming from Canon, I really wish Pentax adds a "My Menu" setting.
04-30-2021, 05:35 AM   #40
QuoteOriginally posted by stevenike Quote
Done!
You can do a lot of customizing of things on the info screen, which saves from rooting around in the menus a lot of the time. The only thing I find myself routinely needing from the menu system that canít be on the info screen is format. However, they now put that in a really easy spot at the top of a menu section.
04-30-2021, 06:48 AM   #41
Custom User Title
FozzFoster's Avatar
This video from yesterday may help
PentaxTips: YouTube Channel - Page 3 - PentaxForums.com
04-30-2021, 06:24 PM   #42
idontstairs's Avatar
I updated the firmware on mine. I can't notice any difference because I updated as soon as I got the camera. It did seem to update a lot faster than the recent K3 and KP firmware updates I just did.
05-18-2021, 05:09 PM   #43
Seeker of Knowledge
aslyfox's Avatar
just updated the firmware on my K 3 III to v1.01
Firmware Updates | PentaxForums.com
first time I tried it, a couple of days ago, would not work
don't know what I was doing wrong
tried again today, no problem real quick
05-18-2021, 05:14 PM   #44
TimR's Avatar
I updated the firmware on my K-3 III when I first got it.
05-18-2021, 05:23 PM   #45
i_trax's Avatar
Mind Testing?
I just updated my firmware but at first it wasn't working and thought something was wrong with the camera. Then I saw that with this camera, unlike the K1, and other K3's the positioning of the memory cards are reversed. Slot one in the K3 iii is where #2 is in the other cameras. :-)
Good , it keeps our brain active
aps-c, dslr, firmware, firmware for k-3, iii, k-3, k-3 iii, k-3 mark 3, mark, pentax, pentax news, pentax rumors, performance, press, ricoh, software, stability, type
Pentax K-3iii available for pre-order in Australia PJ1 Pentax News and Rumors 364 1 Day Ago 05:32 AM
K-3 BULB MODE issues on Firmware V1.11 V1.20 V1.40 gedasst Pentax K-3 & K-3 II 8 01-16-2019 02:04 AM
K-01 Firmware update - V1.02 Docrwm Pentax K-01 42 05-04-2013 06:04 AM
Firmware update v1.01 for Q10 Mistral75 Pentax Q 3 02-20-2013 03:55 AM
Comparison of K-5 low light focus accuracy with v1.01 and v1.03 of firmware tram57 Pentax K-5 & K-5 II 3 03-20-2011 08:13 PM
All times are GMT -7. The time now is 11:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
