04-29-2021, 01:54 PM   #1
jerryleejr's Avatar
Tripod adapter?
Just got my K3iii and swapped my arca mount from my K5iis over and even though the screw is tight the mount isnít. Thereís even a pad between the plate and camera for my hand strap. Iím not gonna tighten the screw anymore for fear of stripping the head. Did something change with the design?
JJ
04-29-2021, 02:11 PM   #2
rogerstg's Avatar
QuoteOriginally posted by jerryleejr Quote
Just got my K3iii and swapped my arca mount from my K5iis over and even though the screw is tight the mount isn’t. There’s even a pad between the plate and camera for my hand strap. I’m not gonna tighten the screw anymore for fear of stripping the head. Did something change with the design?
JJ
Maybe the threaded insert in the base of the camera is shallower, causing the screw to bottom out.
04-29-2021, 02:14 PM   #3
If you have a spare 1/4 20 screw laying around measure the depth of the socket in the camera and see if the screw threads all the way in. Check the threads for damage. I think you got a battery grip too. Any problems with that?
04-29-2021, 02:17 PM   #4
QuoteOriginally posted by rogerstg Quote
Years ago, I (maybe!) "overtightened" the screw securing the camera (Samsung GX10, i.e. a K10D clone) body to the tripod, and it caused the socket in the body to become loose - Samsung then fixed the body by (I assume) fitting a new socket under warrantee.
Thus this could be a similar issue.
04-29-2021, 03:06 PM   #5
jerryleejr's Avatar
QuoteOriginally posted by jeallen01 Quote
Itís a brand new cameraÖ
JJ
---------- Post added 04-29-21 at 05:07 PM ----------
QuoteOriginally posted by gaweidert Quote
No grip (touchy subject)
JJ
04-29-2021, 06:00 PM   #6
Otis Memorial Pentaxian
The contour of the bottom most certainly changed. If your plate has a lip or similar features to prevent rotation, those may be part of the problem. Likewise, any area that not flat may also be an issue. What plate are you trying to use?
FWIW...I was wondering if the Acratech plate I use with my K-3 would work with the K-3iii. I have my doubts due to changes in the camera bottom.
04-29-2021, 07:34 PM   #7
mlt
Generic, flat plates should not have any issues. You may need to wait a bit for a plated specific to the K3iii
04-30-2021, 07:24 AM   #8
jerryleejr's Avatar
Here’s the plate…
JJ
04-30-2021, 11:02 AM   #9
It’s a brand new camera…
JJ
My GX10 was only a few months old when the problem happened - and it never re-appeared after Samsung "fixed" it.
Edited: IIRC, the tripod bush in the camera body was in an "insert" which was fitted into the base - and that insert appeared to have come loose.
I don't know how Samsung "fixed" the problem, but maybe they simply replaced the insert &/or they used high-strength "threadlock" liquid (or even "superglue").
aps-c, body, camera, dslr, grip, jj, k-3 iii, k-3 mark 3, mount, samsung, screw, socket, threads
For Sale - Sold: Tabletop tripod & tripod heads MJL Sold Items 3 11-19-2012 09:59 PM
Tripod Strap vs Tripod Bag vs Nothing At All reivax Pentax Camera and Field Accessories 16 01-10-2012 07:58 PM
Tripod head stuck on my tripod... Buddha Jones Pentax Camera and Field Accessories 11 06-04-2008 07:34 PM
to tripod or not to tripod THAN THE SWORD Pentax Camera and Field Accessories 3 07-11-2007 04:53 PM
All times are GMT -7. The time now is 06:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
