Originally posted by reh321 The term “bake” is used in a pejorative way, but all it means is “cannot be reversed”,...
What do you mean "
all it means"?
That's
the problem, that the processing is destructive, i.e., non-reversible.
There is nothing "
pejorative" about calling a spade a spade.
Originally posted by reh321 ...but that is true of any change made to the pixels before they are delivered.
Of course that is not true.
Adding a constant, multiplying by an integer factor, lossless compression, etc. are operations that can be reversed.
Originally posted by reh321 Who would want to add noise anyway?
No one.
The point is to not meddle with the capture noise because it contains signal below the noise threshold.
Originally posted by reh321 No one has clearly shown that the noise reduction is harmful to an image.
That does not need to be shown, it is known.
If you do not trust your own eyes, it would help to read about signal processing. Consider a crossover component in a two-way loudspeaker. The woofer receives a signal where high-frequencies have been attenuated (the order of attenuation depends on the filter design, a first order design will dampen high frequencies with 6dB/octave). Do you think you can somehow reconstruct the full audio signal (with all its frequencies) at the woofer output of a loudspeaker crossover? Well, you cannot. Once the higher frequencies have been attenuated, they cannot be reconstructed anymore.
Denoising is essentially just applying a low pass filter to image data (rather than audio data).
