05-12-2021, 03:24 AM   #1
pixel shift mode - multiply resolution
Hi all!
I have been searching for a while but I cannot find any photos from k3 III with pixel shift res.
Well, ok I have found it but all of them are 26mpx . As far as I remember in K1 it is possible to multiply resolution 4x in this way. Is it possible now in K3 III?
Regards,
K.
05-12-2021, 03:37 AM   #2
QuoteOriginally posted by krzys128 Quote
Hi all!
Regards,
K.
Pentax Pixel Shift doesn't multiply resolution. It rather removes Bayer array dependency and delivers absolute sharpness only limited by lens and sensor, less noise and maximum dynamic range
05-12-2021, 09:43 AM   #3
Otis Memorial Pentaxian
Perhaps in an alternate reality, but in this universe, pixel resolution for pixel shift is always the same as that for the sensor.
05-12-2021, 09:43 AM   #4
05-12-2021, 03:49 PM   #5
Hi all!
Regards,
K.
you may be thinking of other brands. Olympus and Sony both upsample the pixel count which can still lead to demosaicing artifacts though at that high MP a downsize with a good resampling filter should fix it. Pentax upsamples the subpixel array which gives you the full RGGB array for each pixel, theoretically eliminating any demosaicing artifacts.
aps-c, dslr, iii, k-3 iii, k-3 mark 3, k3, pixel, pixel shift mode, resolution, shift
Pixel Shift Resolution Extraction. asterfaos Pentax K-1 & K-1 II 3 03-11-2021 09:19 AM
Can't use Pixel Shift Resolution in B mode astrojim Photographic Technique 15 05-21-2020 10:16 AM
Lloyd Chambers Prefers Pentax Pixel Shift To Sony's Pixel Shift Fenwoodian Pentax K-1 & K-1 II 2 07-16-2018 02:15 PM
K-1 multiply exposure question, how many images have you tried to compose? micromacro Pentax K-1 & K-1 II 9 10-05-2016 10:03 AM
An analysis of the Pentax K-1's "Pixel Shift Resolution" mode - Image resource Oli86 Pentax K-1 & K-1 II 7 05-06-2016 07:19 AM
All times are GMT -7. The time now is 12:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
