Originally posted by snappyhoffy But that states that it effects P, Sv, TAv and M but not AUTO.... but I will continue to 'play'.
Thanks for your suggestion though.
I believe it is we who are agreeing to 'play". Since there are no obvious menu settings that allow setting an aperture range for any purpose it is probably not a setting. Using a different program curve might work except that Auto mode sort of makes that decision for you based on scene analysis.
FWIW, variations of this thread come up every once in awhile where the user wants to stipulate a range of apertures for program auto exposure in a manner similar to restriction on ISO for auto-ISO; a common suggestion being to set minimum ISO to a fairly high value to force narrower apertures. Auto mode should respect the ISO range restrictions.
For your case, setting one of the User modes to be "Auto" with ISO range restriction might be a workable solution. You can call it "Heat of the Moment" mode.
