Originally posted by caliscouser Only had a few hours with this camera and don't have any opinion yet on whether there is any problem here or whether it is just different.
However some things that may make it easier and some ideas that could be implemented in firmware.
Easier:
1. Mapping the RAW button to viewfinder light = on. The red lights stay on all the time until you toggle the button again (in AF-C they stay on except when you hit the AF button)
2. Turning off most of the OVF LCD overlays like frames, grids and AF points helps so that only the actual focus points illuminate in red. (easier to see)
Firmware suggestions:
1. Make focus points flash red for a longer time, too quick currently and quicker than the KP
2. The focus point overlay consist of a small square inside a big square. turning both squares on and flashing red would greatly increase visibility
3. In AF-C, if viewfinder light is on by the user, keep it on while AF button is held.
4. Add a new 'high visibility' viewfinder mode that basically implements all of the above to deliver something close to what you get on other models like KP, K-70 (if you want it)
This all makes a lot of sense. The raw button is useless for me, and it's in the right "neighborhood" ie where the AF stuff is.
I already turned off all the other stuff to make it easier to se the points that's a good tip.
The K1m2 points/light seems to light for longer and are clearer. So there are things they could do in firmware and probably will to make it better. BUT, it's really not much of a problem if at all, in use so far.
