Originally posted by wkraus As a follow-up to my last post, here is a test shot (an old Paterson test target) developed with and without Pixelshift to demonstrate its effects. The lens used is the SMC D FA 50mm F2.8 Macro at f/6.3. I used three different raw converters, Adobe Camera Raw 12.2 (no Pixelshift functionality as yet), RawTherapee 5.8, and Digital Camera Utility 5.9. Incidentally, this also demonstrates how differently the demosaicing works at pixel level – but the test pattern is a real stress test, under normal conditions the differences are less obvious.
These are full-size crops. I edited the images for identical luminosity and contrast and neutral grey, but did not attempt to get similar colours. Due to the complexity involved, I also did not try to apply the same sharpening. In DCU sharpening is set to zero but nevertheless the software seems to apply some rather crude sharpening.
Adone Camera Raw:
RawTherapee:
Digital Camera Utility:
Feel free to download the images if you want to take a closer look.
Now that I have owned a K-3iii for 3 months, I thought I had better try out the pixel shift comparison myself, using the excellent HD DA 16-85mm F3.5-5.6 ED DC WR Lens.
I am sure if I posted the before and after images, the web resolution would be insufficient to show a resolution difference. However, processing both RAW images in exactly the same way and zooming in tightly on the computer monitor, the increase in resolution is evident in the fine detail, which is impressive.
