Originally posted by Not a Number Thank you for the tip.
I don't use Linux and know next to nothing about it. The K-3 mark III use MTP (Media Transfer Protocol) with the USB connection so I would guess using the MTP mount options would work as well.
You are correct—the only protocol available in the K-3 III for file transfer is MTP, and that is what my software will use for the K-3 III.
The "UNIX way" involves low-level services (or "daemons") as an interface layer between physical devices and applications. Every program that wants to download files from the camera via a USB cable goes through the "gphoto2" service, which negotiates with each USB device to discover and use the appropriate file transfer protocol. In practice, I
simultaneously download photos from both cards in my K-1 (via PTP orMTP for videos), both cards in my K-3 III (via MTP), my iPhone (via file system mount), and sometimes both cards in my Nikon (via PTP or file system mount). Because of the middle-ware server, I don't know and don't have to care which protocol is being used for which device, and they can all dump their new photos as quickly as possible.
Simultaneously, as in "all at the same time".
It makes me happy!!!
