Originally posted by RobG
The gimbal looks amazingly effective. Does the camera do CAF all by itself as long as you're recording?
No, I did buy focus motor and focus lenses manual, from wheel in that gimbal. I don't have to touch lens unless I want to zoom, but that I will do propably between the shots. Gimbal is super effective IMO. I did just try it with BMPCC4K and AF is not as intutive through gimbal and USB, so I'll stick with focusmotor with that camera too.
I'd recommend this gimbal in a heart beat, but only with focus motor. in total of 680€ it is not that big investment. Althou IF you are not going to use bigger cameras, then a bit smaller gimbal could do. This does carry BMPCC4k and 6K(pro too) with out problem(well I should buy extension bit for BMPCC use, but with my use so far I don't need the 'whole movement range), so it'll be good for many kind of work where I need it.
---------- Post added 09-15-21 at 14:11 ----------
I recorded a couple more test clips today and the AFC isn't behaving how I expected. I'm not sure if it helps to post a video showing failed AF if the cause is user error.
I suppose that you used 16-50 PLM. I'm interested of which mode did you use and how did it go. Since this lens is in my mind for gimbal use and I'd like to 'trust' AF with it, since it should have AFC and face detection ect. perhaps it is video settings?
---------- Post added 09-15-21 at 14:23 ----------
Originally posted by biz-engineer
Wow, K3III does 4K videos. Will get better ratings from DPReview. K3III does it all, fast FPS, 101 AF points tracking, and 4K video (with mechanical SR!?), it's getting hard to find excuses not to buy a K3 III
.... ah yes, I forgot.. "now the price is too high"
Yes, indeed. I suppose that Ricoh wanted to give good alternative for MILC also with video in mind. SR(yes mechanical) is good, but it could be more effective. Why I bought gimbal. For handheld shots SR is okay and when you turn it off, you'll see how much it actually do help you.
4K quality is 'good enough' and for some instances you don't simply need more. just make sure that you use somethign to steady your shots(tripod and slider is very good combo(as well as gimbal is)) FHD quality is very good.
I did just look alternative, like Panasonic S5. I lookd couple of videos and I did notice ugly jelly(they were runnin on the street and trees went like / / /) Have a look of me running up hill and trees are like | * it does have jelly, but compared to that it is just as bad or even less. I thought that I can do better with K-3III so I won't have to use big €€€ for other system. That said, other systems do have their strenghts, what they do lack is mirror and this 6 letter word at front. Pentax.
Yes it does cost quite a bit, but so far I'v been happy. Need to explore more. I have proper video cameras for the kind of work when I need to step up, and going to uppgrade those too. This K-3III is nice run and gun and it does pretty good with photos too
