Originally posted by pzman3d Hello ~ i love your channel and video~
if you want get clean hdmi video to live stream with the K3 III.
you need use "LV" mode not "video record mode"
and you can go to Monitor Display > Live view > Shooting info Display > L1/L2/L3 Customization > to setting a Clean mode for your live stream.
next time you can use "info button > info button > info button" to switch clean Monitor Display for your live stream.
I hope that will help you.
I was experimenting with this tonight with a cheap HDMI video capture dongle and found it works pretty well using liveview - once I turned off the 'auto power off after 1 minute' setting...
The one issue is that, unlike video mode, in liveview it doesn't stop the lens down to the selected aperture setting, so you're limited to the maximum aperture of the lens you're using.
Interestingly, if you put the camera in M and enable 'Exp Simulation LV', which simulates the exposure in LV by brightening or darkening the image, the camera does stop down the lens when it needs to to achieve the appropriate darkness in the image... but you can't really control this, and it's set up so that if you're at 0EV then the lens is wide open.
