Closed Thread
Show Printable Version 15 Likes Search this Thread
05-31-2021, 06:24 AM   #1
Unregistered User
Guest
So... What about the AF?
I was wondering if the AF of the new Pentax K-3 III is any better than previous versions and if so, how much?
What's new?
05-31-2021, 06:43 AM - 1 Like   #2
There’s a bunch of threads on this subject already. You might start by looking at them.
05-31-2021, 06:48 AM   #3
QuoteOriginally posted by Tjompen1968 Quote
What's new?
Yes, it's better … how much? … what are your parameters?
05-31-2021, 07:40 AM   #4
Kobayashi.K's Avatar
QuoteOriginally posted by mtkeller Quote
I sometimes think it's 50% of the forum.
05-31-2021, 08:34 AM   #5
Unregistered User
Guest
So, I did a search and did not find the answer I was looking for. Just a lot of questions with guesses as answers.
So, do you have any posts I can look at?
---------- Post added 05-31-21 at 05:35 PM ----------
QuoteOriginally posted by kypfer Quote
I do not know what you mean with "what are your parameters?"
My question is if it is useful or if it is as useless as before but just a little better?
05-31-2021, 09:53 AM   #6
pres589's Avatar
Hey mods, is there a way to call out this obvious trolling without getting a stern talking to? Because this seems to be the opposite of the spirit of the forum.
05-31-2021, 09:57 AM   #7
Here’s one of the many, many threads on the subject: AF-C of K-3III is impressive - PentaxForums.com
05-31-2021, 10:51 AM   #8
All reports suggest it's knocking on the door of D500 level AF but with a smaller buffer.
A huge step forward over previous Pentax bodies. Does that answer your question?
If you need more detail, do some more research in the K3iii sub-forum for your specific use case.
05-31-2021, 01:41 PM - 1 Like   #9
Unregistered User
Guest
QuoteOriginally posted by pres589 Quote
This is not trolling at all. Maybe a little provocative but no trolling whatsoever.
The AF on all Pentax cameras before has not been good. A little better every time but never good.
Using the K-1 with DFA150-450 and AF.C is useless. It is unable to track most of the time so it is AF.S with Spot or Small trying to focus and shoot. I have very good technique and nowadays I get a pretty high amount of sharp images shooting wild life.
So I want to know if the AF now is able to track a bird or a deer and get sharp images. If the eye-AF is a gimmic or useful.
No need to be so defensive. I am a hardcore Pentaxian.
---------- Post added 05-31-21 at 10:43 PM ----------
Thanks, I will check that one out.
---------- Post added 05-31-21 at 10:45 PM ----------
QuoteOriginally posted by caliscouser Quote
I heard that to, wanted to hear from new users what they think. If it is as good as one want it to be.
I have received my copy of the K-3 III but have not been able to test the AF.C yet.
05-31-2021, 02:39 PM - 2 Likes   #10
Kobie's Avatar
The K-3 III AF.C is absolutely leaps and bounds better than anything Pentax has previously done.
As a matter of fact, it's so much better, that even my screw drive lenses aren't so bad to use anymore while tracking birds (I'm talking about a Sigma 170-500 APO, the older non DG version). The camera is more "aware" of what to do with the AF and it doesn't hunt anymore with screw drive lenses (at least not nearly as much as before). DC and PLM based lenses are VERY quick to lock focus. The AF is now MUCH more decisive in AF.C. It's honestly hard to believe that Pentax, ya PENTAX made this thing. The experience is that different.
Just over the weekend I was doing another YouTube video and had my K-3 with me. I shot with the K-3 III then switched the lens over to my K-3. It took all of maybe 20 seconds before I muttered "Oh my god, this is weird. I loved this camera, but wow does it just feel slow and clunky". SO ya, tracking action whether it's on the ground or things in flight, being able to capture those split second opportunities, we finally have that camera.
The K-3 III is a "sum of all parts" camera. It's not just the vast improvements in AF, it's how fast the camera responds to EVERY input as well. It's just a darn fast camera in general.
Now, as for the eye-AF, it's not a gimmick, but you need to also keep in mind that this is a first generation implementation of eye-AF into a DSLR and can't be compared to mirrorless expectations, it won't even come close. It does work, but in limited scope. Yes the AF may seem to track, but when you take the shot, it may not have focused directly on the eye, maybe the ear, eyebrow, cheek bone just below the eye, those are usually what I end up with along with a couple that are clearly focused on the eye. Distance from the camera seems to play a part (headshots do well, torso and up not as well, full body? Forget it).
I'm still doing some more testing on it. Also, the subject recognition (for face/eye detection in OVF) only works in full auto AF or Zone AF as long as you have subject recognition turned on in the menu.
05-31-2021, 02:48 PM - 1 Like   #11
Unregistered User
Guest
QuoteOriginally posted by Kobie Quote
As a matter of fact, it's so much better, that even my screw drive lenses aren't so bad to use anymore while tracking birds (I'm talking about a Sigma 170-500 APO, the older non DG version). The camera is more "aware" of what to do with the AF and it doesn't hunt anymore with screw drive drive lenses (at least not nearly as much as before). DC and PLM based lenses are VERY quick to lock focus. The AF is now MUCH more decisive in AF.C. It's honestly hard to believe that Pentax, ya PENTAX made this thing. The experience is that different.
Thanks! Sounds hopeful!
06-01-2021, 02:25 AM   #12
Lab tests are still forthcoming. But I have no doubt AF has been substantially improved for tracking moving subjects. The K-3 III has obviously been designed for greatly improved performance of burst shooting, with much higher frame rates per second, so AF will have to be upgraded for such a system to work.
06-01-2021, 03:20 AM - 1 Like   #13
noelpolar's Avatar
For a lot of stuff (ie wildlife... birds etc)..... I can still see afs and spot being the go a fair bit of the time. I just spent a week with the K3III and DFA 150-450 in the country.
So.... do you want focus in the head or back feathers?.... I'd go back with a bit more DOF dialed in...
Whilst I'm still to form any strong view..... it is clear this camera delivers a leap in certain aspects of it's focussing capability.... that is real and unprecedented..... however.... when shooting in dynamic situations.... poop in and poop out is what you get. Simple static scenarios are easily managed.... ie Air shows, cars going around a track, dog on a beach etc... get your settings right and it will serve you well..... but in dynamic wildlife scenarious you need to be able to move between various settings effeciently with appropiate knowledge...etc. Given the high standards some have.... this isn't just a simple given.
Given some of the previous pentax focus traits.... a lot of has have ways of managing things..... and getting great results.... now it's play time setting some of these aside and seeing what the camera delivers.... time will tell.
06-01-2021, 07:52 AM   #14
Seeker of Knowledge
aslyfox's Avatar
This is not trolling at all. Maybe a little provocative but no trolling whatsoever. , . .
fail to see why the OP feels the need to be
provocation invites retaliation
i agree with @ pres589
not a very helpful thread IMHO
but what do I know
______________________
perhaps instead of being a little provocative the OP could look at threads posted under the K 3 III section
https://www.pentaxforums.com/forums/210-pentax-k-3-iii/
including the photo thread which show some efforts of photographing subjects using shutter burst mode
https://www.pentaxforums.com/forums/210-pentax-k-3-iii/423608-post-your-k3-i...ml#post5266079
https://www.pentaxforums.com/forums/210-pentax-k-3-iii/423608-post-your-k3-i...ml#post5269779
https://www.pentaxforums.com/forums/210-pentax-k-3-iii/423608-post-your-k3-i...ml#post5286100
06-01-2021, 09:05 AM - 1 Like   #15
Otis Memorial Pentaxian
What's new?
You are an owner, right? Perhaps you can share your experience?
Closed Thread
af, af.c, aps-c, dslr, images, k-3 iii, k-3 mark 3, money, pentax, pm, post, question, time, track
Nature So pale so delicate eaglem Post Your Photos! 2 01-29-2021 03:32 PM
Travel Cactus and sea: Water; so near, yet so far ismaelg Post Your Photos! 5 12-15-2019 07:56 PM
Nature So so tall, small, so beautiful newmikey Post Your Photos! 3 06-03-2011 03:11 AM
The news is so-so but the pic is good ... Kguru General Talk 9 03-11-2008 09:35 AM
So, so sad. Tragic. Mallee Boy Post Your Photos! 4 09-02-2007 01:21 PM
All times are GMT -7. The time now is 03:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
