Originally posted by texandrews With shutter shock, there can be so many variables... manufacturing tolerances in the individual camera and/or lens, lens model / weight / shape / focal length (if a zoom), hand-held technique, tripod and head supporting the camera, etc. Change any one of those variables and it may introduce, alter or remove the effect of shutter shock, or move it to a slightly different range of speeds.
I can force the shutter shock effect on
my K-3 with
my copy of the Sigma 18-300 at ~24mm and a shutter speed around 1/100s, hand-held. I don't get the "problem" using the same lens and shutter speed on my K-3II, nor can I replicate it on my K-3 if I use my Sigma 17-50 f/2.8 at the same focal length. My conclusion, in this particular instance, is that there's something about the combined mass and dimensions of the K-3 + Sigma 18-300 when set to that focal length. That may or may not relate to the effect DPR is seeing and the reason why the quoted user can't reproduce it, but it shows how difficult it can be to confirm if, and why, the behaviour occurs.
As an aside, I've previously mentioned how some guitars will have a "dead spot" where a particular string, at a particular fret, will sound muted and won't ring out as expected. Assuming it's not due to a raised fret and the neck has proper relief ("bow"), it can often be improved, resolved completely - or, sometimes, merely moved to a different spot - by adding mass to the instrument. A clip-on metal weight is usually added to the headstock to achieve this.
