07-19-2021, 07:29 PM   #1
Slot 2 and SD card compatibility
You can ignore me if you want but please do check your SD card compatibility in slot 2 before going out on an important shoot.
I have this old-ish SD card - Kingston Ultimate 128GB that was in my K-5IIs. It works ok in slot 1. But when used in slot 2, it only records 10 to 15% of all the photos I took. I can see the buffer trying to write to it and then fails. The strangest thing is immediately after taking photos, I can see the total numbers of files decreasing. I.e. if I take 10 photos and view it at the rear monitor, I can see 10 becomes 9, then becomes 8, etc.
But when using the same Kingston card in slot 1 there is not even a single problem.
I then tried using the latest Kingston Canvas react plus 128GB UHS-2 SD card and some very old and SLOW Sandisk 32GB cards on slot 2 without problem.
I repeated these tests over 500 photos and the results are very consistent. Luckily I discovered this problem while calibrating my lenses and not shooting something important.
07-19-2021, 08:24 PM   #2
UncleVanya's Avatar
QuoteOriginally posted by sbc Quote
That’s very odd.
07-19-2021, 11:02 PM   #3
sbc
I installed the latest ver 1.1 firmware and the problem disappeared, for now. I shot about 20 frames and all are recorded properly.
128gb, aps-c, card, compatibility, dslr, k-3 iii, k-3 mark 3, kingston, photos, sd, sd card, slot
K3 Mk.III writing to the "wrong" SD card slot oneill Pentax K-3 III 13 06-20-2021 09:21 PM
K1 SD card slot k2parn Pentax K-1 & K-1 II 7 01-27-2021 06:46 PM
How much is a new SD card slot for my pentax k5 Brian Baxter Visitors' Center 3 03-07-2020 08:19 AM
On K1, the card slot 1 is grayed out when choosing how to write to each slot. Why? duogl Pentax Camera and Field Accessories 5 03-29-2019 04:25 AM
All times are GMT -7. The time now is 09:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
