07-22-2021, 09:16 AM   #1
Occasional delay coming out of standby
After singing in the cameraís praises, I have my first issue. Occasionally when I wake the camera up from standby mode, the memory card light will light up and the camera will be inoperable for about 7 seconds. Iíve missed some action shots because of this. Iím at high ISO (6400 or 10000) continuous AF, and high speed burst mode when this happens, but I think it might have to do with recording JPG's to both memory cards. This didnít happen when I recorded to only one. 2nd card is slower (95MB/s). Anyone had this happen to them, or any ideas how to fix it?
07-22-2021, 09:36 AM   #2
I've not (yet) experienced this problem, but I only use one card (skinflint!)
Initially I'd try interchanging the cards.
I believe there are some specification differences between the two slots, though one really needs a modicum of repeatability to be able to define the cause of the problem.
Alternatively, two cards of the same specification may help isolate the issue, but again, one would need to be able to repeat the issue reasonably reliably to be sure it had been isolated.
Good luck
07-22-2021, 09:38 AM   #3
photoptimist's Avatar
That sounds like a problem with the card(s). Reformatting the cards in the camera (after making absolutely sure you have backups of the data) might help. Or, trying a different card might tell you which card is causing the delay.
Good luck!
07-22-2021, 09:41 AM   #4
jatrax's Avatar
You could also try it with only one card in and see if the problem occurs. Might help to determine if it is a card.
07-22-2021, 09:45 AM   #5
Seeker of Knowledge
aslyfox's Avatar
if one has a UHS II card in slot 1, it is the fastest way to use the camera
[ remember that unlike the K 3 and K 3 II, or the K 1 and K 1 II, the K 3 III's slot 1 is the one closest to the back of the camera ]
if one puts a UHS II card in slot 2, however, the camera treats it like a UHS I card
see pg 42 of the manual
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-3-3.pdf
aps-c, camera, card, dslr, happen, k-3 iii, k-3 mark 3, light, memory
K-1 Standby screen default? RickC Pentax K-1 & K-1 II 4 12-18-2016 06:20 AM
current FA limited in standby Glorfindelrb Pentax News and Rumors 3 04-21-2015 05:30 AM
PENTAX 360FGZ standby time?? kooks Flashes, Lighting, and Studio 12 09-29-2014 02:09 AM
*ist DL doesn't always wake up from standby mode bonitap Pentax DSLR Discussion 2 06-25-2010 07:16 AM
Standby of K20D 4pisr Pentax DSLR Discussion 11 09-09-2008 12:22 PM
All times are GMT -7. The time now is 08:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
