Originally posted by Robert N
compatible with a Metz 52 AF-1 flash
Your Metz will need to take its sync from an RX (receiver) compatible with the transmitter. Unless you are in the Cactus universe*, that means the Metz will be reduced to operating as a non-TTL manual flash with setup done on the flash. As noted above, Godox is the best option at present if you need remote TTL from a Pentax camera. If TTL is not a strong requirement, either Godox or Yongnuo systems get the thumbs-up from me. (I have components from both and yes, they can be intermingled with discretion.)
* As noted above, that ship has sailed. Cactus is no longer in the lighting business.
Reason: Clarity
