I doubt back button AF and shutter button would drive different auto-focus algorithm. What could make user believe that back button AF behave differently is due to initial state of focus and variability inherent to image pattern recognition. Repeated shutter half press may not give the same auto AF point selection. Testing is there is a difference between back button AF and shutter AF would require statistical sampling: focus 30 times with back button AF (make sure target doesn't move and lens initial position is always de same) and 30 times AFC with shutter button, not AF point each time, compare statistics.
---------- Post added 28-07-21 at 13:21 ----------
Originally posted by Madaboutpix where it would erratically jump to various suboptimal focus points instead of focusing on the most contrasty subject.
If there was already AF lock on a point, a new attempt to focus will select the next nearest point. Typical behavior of auto-AF point selection on my K1. It's quite smart. We need to understand how our gear works before claiming it's faulty.
---------- Post added 28-07-21 at 13:24 ----------
Originally posted by Madaboutpix Whatever caused this, it would seem that back-button and shutter operation yield different results in AF point selection, which clearly shouldn't happen.
The first "inconsistency problem" would be that pressing two times the same shutter button doesn't lock AF on the same point. If there are two areas in an image target which have the exact same contrast, computer have no feeling, it's will randomly switch from one area to the other depending on random error of phase detect measurement.
