Originally posted by MTNcycler ...This was my first time out after updating to firmware ver. 1.10. Maybe they fixed it?...
After my
first picture with the camera - I had to click something before doing anything else - I upgraded to 1.10 firmware. So comments about AF and the camera going blank are based on that version of firmware. I can't comment on earlier versions as I didn't try them.
Whereas I like the PLM 55-300, from experience with the lens on a KP it works best (or at least my copy does) at F8 and up to about 200mm, above 200 and at larger apertures the lens is soft. As this is limiting, I ordered a 60-250 F4 to go with the K3-3 but that has gone back, before I even tried it, as it had a vey noticeable tight spot on the zoom around 135mm. I will be interested to see how the K3-3 performs with an SDM lens. As it is early days I also have to try the various screw lenses I have, again to compare with the KP.
Though given my first impression of the K3-3 I am feeling sorry for the KP as I suspect that going forward it will see little use.
