As you may be aware, Lenstip is one of photo gear benchmark websites run by a Poland-based group calling themselves Optyczne.pl (Polish for 'optical'). Lenstip.com is their collection of camera lens reviews translated into English; similarly, allbinos.com are a collection of their binocular reviews.
However, they also test cameras, and their newest is K-3 III review.
The test isn't (and probably won't be) translated by them into English; I'll try to recap the most important points they made, and also leave a link to original, in case someone would like to check it out.
Test Pentax K-3 III - Wst
Without further ado:
1. Build quality/ergonomics/menus/user experience
They recognize K-3 III as a solid camera with lots of customization options. They liked all the dials, the rear touchscreen, as well as the OVF, which they compared to Canon 5D III and Nikon D3X; they said it's basically identical to Nikon's and only a little bit worse (in terms of magnification) than Canon's. They had no problems with batteries, which easily allowed claimed 800 shots. They also liked the wifi and smartphone app pairing functionality.
They didn't like that the grip is a little too short and has no sufficient space for the pinky finger.
2. Features/Autofocus
They tested AA filter simulation and pixel shift resolution, and were satisfied with results delivered by both modes. Motion correction for PS files works really well.
They pointed out lack of built-in GPS, which prevented them from testing Astrotracer.
They tested IBIS (with DFA* 50mm) and found the effectiveness to be on a level of 4 EV, which they said was an excellent result.
While testing burst mode, they found out that the tempo is not exactly equal to 12 FPS (more like 11), but they acknowledged that Ricoh declares the top speed assuming ISO 100, and for higher settings it could be slower. For a 30s long series, they made 58 RAW files. The FPS rate seems to drop considerably after 2 seconds of continuous shooting (while shooting RAW, with JPEG it's 5 seconds).
They weren't particularly impressed with both AF-S and AF-C. During AF-S tests, they found that noticable amount of pictures were missed by more than 20%, in LED 5400K light. Things were much better in tungsten light, and this is one category where K-3 III fared better than D500.
For AF-C, they used DFA* 70-200. For auto point selection from full coverage, they earned a keeper rate of 46%. Things improved to 53% for 5-point mode. Both Fujifilm X-t4 and D500 fared noticably better.
They claim that the main AF doesn't provide any sort of face/eye detection. I believe they are incorrect on the matter, but I guess it's certainly a challenge to find in the manual, how to set it up.
They also made a filmmaking oriented, full separate test few days ago. To put it short, they didn't like the cropped 4k, overheating warnings (the camera didn't overheat though) nor abysmal AF in video.
3. Resolution/noise/DR
For resolution tests, they used DFA* 50 and Sigma Art 35mm. The measured resolution was less than X-T4 and D500, but not by much. Pixel Shift mode bumped up the resolution by 30% in JPEGs, and around 22% in RAW (developed with DCU). They found no signs of sharpening in PS files.
As for noise, they noticed some sort of anomaly at ISO 400. They suspect either denoising or dual-gain (which would result in different behavior of ISOs 100-200 and 400+). They didn't find much evidence supporting the latter; for example, the readout noise measurement didn't show the same level of difference between ISO 100-200 and the rest.
It seems that the noise levels are very similar in all three cameras compared, but the lead belongs to the Fuji.
ISO 1600 seems to be the limit, where setting the ISO in camera yields better results than lifting it in post.
As for dynamic range, they found that at base ISO, Pentax gives 362 tones, resulting in 8.5 bit data. Fujifilm's result was 8.6 bit, and D500 8.9 bit. The DR measurement plot for different ISO shows again an anomaly when going from ISO 200 to 400; they don't know what could be the cause, they don't seem convinced that it results from dual gain architecture, due to readout noise measurements.
Measured dynamic latitude at ISO 100 is equal to 9 EV. X-T4 got 0,1 more, D500 0,7 more.
When lifting exposure in post by 4 EVs, they liked Pentax results more than Fujifilm's.
4. Summary
They feel the camera has indeed an appeal for those prefering DSLRs. However, they feel that its main competitor in this regard, Nikon D500, is way better value for the money. You can also grab Nikon Z6 II for the price of this Pentax.
