(I thought this item would be better placed in its own thread, rather than in the thread on K-3 III Tips and Tricks at
K-3 iii tips and tricks (let's all contribute) - PentaxForums.com)
I would appreciate if someone would go through the steps to confirm that I've described the set-up and use properly, and that it works. Also, please let me know if this or another method has already been posted. I didn't find anything in my search here (just various members lamenting the U1, U2 display...
- Craig
When the Mode Dial of the K-3 Mark III is used to select a
User Mode, the User Mode is identified as U1, U2, etc, on the Status Screen. The descriptive name that the user has made does not appear. This is inconvenient and time-wasting.
Basically, each User Mode 1 to 5 can be assigned to one of ten pre-saved and named 'Boxes' of favourite settings. Here is a work-around that displays the name of the User Mode and provides a convenient way to select the settings from the ten boxes. The key is the Memo that appears on the left panel of page 101 of the (English) Operating Manual concerning the [Recall User Mode Setting].
Set-up
1. Save your frequently-used settings in BOX1 through BOX10, and name the Boxes (Saving the Settings, page 100). For convenience, initially assign BOX1 to U1, BOX2 to U2, and so on to BOX5/U5.
2. In the rear Control Panel, register
[Recall User Mode Setting] as one of the Control Panel items (Customizing the Control Panel, p. 106). The small icon square will display BOX1 as its default.
Using the User Mode
1. Set the mode dial to U1.
2. Display the Control Panel on the rear screen.
3. Select the icon for [Recall User Mode Setting] (BOX1) on the Control Panel.
4. The name of the User Mode will be displayed at the top left of the screen.
5. To select another User Mode, leave the User Mode dial at U1, and scroll the
rear e-dial to change the BOX (Changing the Settings, p. 101). (Alternatively, change the Mode Dial to another User Mode to go directly to its saved BOX.)
