Originally posted by jersey Nope, it does not? At least I never got this issue. When camera slows down (you can hear it) all you need to do is to release a finger for a moment and press again. You get additional 5-6 frames and higher speed when part of buffer is cleared. Can repeat it till you run out of card space. Also when you stop buffer clears really fast to zero. '
Maybe your card is an issue here? Not all UHS-II cards have same writing speed. I have U3/C10/V90 so it is fastest UHS-II available currently. I am not really sure what protocols are used to clear buffer, but it really clears fast and I never saw my camera being unusable. The moment buffer is full I release shutter and press it again - it works.
I bought a SanDisk Extreme Pro 300MB/s U3/C10/V90. I don't know what would be faster? I am not investing more money into anything else because the camera can't keep up with the card. It's not the card that can't keep up with the camera. I don't think there is a difference when using a UHS-I Sandisk Extreme Pro 170MB/s U3/C10/V30 card.
My K-3III craps out after 30 RAW frames. It shoots 2 more RAW frames after the buffer fills with the initial 30 RAW frames at a extremely reduced rate and if you remove your finger from the shutter it takes multiple seconds to clear so you can shoot again. The gap is long enough if you are shooting anything that moves it will be gone by the time the buffer clears. Be that a person walking, a car driving, a bicycle rider. Whatever it is. You miss the shot when the buffer is full because the camera can't shoot.
