09-12-2021, 04:08 AM - 1 Like   #1
K3 iii and af360 flash compatibility
Hi,
I recently acquired a K3 iii and really enjoy taking photos with it.
I also own a pentax af360 flash that works fine on my old K5 ii, but flash photos are overexposed when using it with the K3 iii.
Did anybody had this problem? Any ideas about what can be causing it?
Thanks,
Gabi
09-12-2021, 05:22 AM   #2
pschlute's Avatar
QuoteOriginally posted by gabi_drf Quote
Hi,
Thanks,
Gabi
What mode are you using on the camera and on the flash ?
09-12-2021, 05:22 AM   #3
Perfessor5646's Avatar
I very recently, yesterday, discovered I had that issue when using the Pentax flash off camera K3iii with a radio trigger. I do not have a problem with the flash on camera or with a flash extension cable or using the radio triggers with a third party, Neewer 620, flash off camera. Nor with my K3II, I haven’t had the time to investigate it yet.
In my case, it seems the K3iii does not recognize the radio transmitter and jacks up the ISO to 512K
09-12-2021, 06:27 AM   #4
Hi Peter,
On the camera, I've tried regular flash, slow sync and X mode (this one with better results).
On the flash, I've tried master and controller
Thanks,
Gabi
09-12-2021, 10:29 AM - 1 Like   #5
pschlute's Avatar
Hi Peter,
Thanks,
Gabi
Hi Gabi, thanks for replying. For future reference you are more likely to get a response from someone if you quote their reply.....otherwise I may not see your response.
On the camera which exposure mode ?...... Av or M ? I can see you had better results with X-sync. I usually use M mode when using flash, remember shhutter speed needs to be at sync speed or below (1/200 or slower)
On the flash itself, you should not be using Master or Controller mode UNLESS you are using a second flash unit off the camera. If you are using a single AF360 on the camera hot shoe, you need to set the flash to either Manual output or P-TTL.
09-12-2021, 02:20 PM - 1 Like   #6
I used to have more than one AF360FGZ that I used with my K-3 II. I used to use Manual Mode with reasonable settings for what I was doing, for example 180 shutter speed, 200 ISO, and F9 Aperture, possiby for an indoor shot. I would also have the flash in TTL usually. The flash would usually compensate for the settings being used properly, and if I needed to set the flash output lower or higher, I would resort to the flash EV (plus or minus setting of brightness discharged from the flash). Of course you can also adjust your settings to accommodate for a situation, on the camera or flash.
09-12-2021, 03:08 PM - 1 Like   #7
Gabi, according to Pentax that flash should be compatible . Check pages 119 and 120 of the manual regarding setting it up in case something is off in the settings.
09-12-2021, 05:50 PM   #8
Otis Memorial Pentaxian
QuoteOriginally posted by Perfessor5646 Quote
Tell us about your radio transmitter and what is being used as a reciever so we can help with the troubleshooting the flash issue. Your ISO problem is probably a matter of camera settings.
BTW...confirm that shutter speed was at or below sync speed. X-mode is our friend for troubleshooting.
09-12-2021, 07:06 PM   #9
clackers's Avatar
Unlike the 360, that Neewer has no TTL or HSS, it's pretty basic.
And does your radio trigger support HSS?
If not, as Steve said, check your shutter speed. It needs to be 1/180s or slower.
09-12-2021, 09:43 PM   #10
Peter,
Thank you for your reply.
I was using P exposure mode. I'll try it with your suggestions.
Thanks a lot!
Gabi
---------- Post added 09-12-21 at 09:49 PM ----------
QuoteOriginally posted by VSTAR Quote
Hi VSTAR,
I'll check the manual.
Thanks,
Gabi
09-13-2021, 01:31 AM - 1 Like   #11
pschlute's Avatar
You are welcome to post some pictures on here if you are not getting consistent results. The AF360 is a fine flash unit.
09-13-2021, 07:16 AM   #12
tonyzoc's Avatar
With my 360FGZ and K-3iii I'm not getting overexposure... maybe a slight bit underexposure.
The first picture is default exposure and the second picture is +1 stop comp.
09-13-2021, 08:45 AM - 1 Like   #13
Gang, I’m not ignoring this thread. I’ve been too busy to do a hands on experiment. Please carry on.
af360, af360 and k3iii, af360 fgz flash, af360 flash, aps-c, camera, check, dslr, exposure, flash, flash compatibility, iii, iii and af360, k-3 iii, k-3 mark 3, k3, k3 iii, k3iii, mode, photos, response, thanks
K3 iii Live view and focus peaking compared to K3 speagles2 Pentax K-3 III 17 09-29-2021 10:21 AM
K3 iii vs K3 vs K1 low light performance? bobbotron Pentax K-3 III 19 08-26-2021 06:07 AM
K3 vs K3 mark III as best deal ? bygp Pentax DSLR Discussion 34 05-20-2021 11:56 AM
Comparison K3 III versus Sony A7 III bwgv001 Pentax DSLR Discussion 51 04-30-2021 01:20 PM
K-x with AF360 and Flash Wave III sync time limited to 1/50th? wmich Flashes, Lighting, and Studio 2 12-07-2010 05:31 PM
All times are GMT -7. The time now is 10:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
