Originally posted by niels hansen but I still dont understand why each lens demands its own fine tune value in pdaf
A very interesting question.
PDAF is not 100% accurate. My experience when doing testing for autofocus adjustment is that it is around 80-90 % accurate. By that I mean that an average lens when tested on an unambiguous target will return
exactly the same focus position only about 8 or 9 times out of 10. I have also noted that on some lenses a different majority result will be obtained depending on whether the lens is made to focus from a starting point of closest focus distance compared to infinity.
My personal view on why this happens is that different lenses have different designs.... screwdrive versus internal motor... different focus "throws".... different weight and mass of glass to be moved. When the PDAF sensor detects focus and tells the lens to stop focussing it can over-shoot and be fractionally further or closer than the ideal focal plane. Not enough for the PDAF to request a refocus, but enough to be noticeable if one looks at a test chart.
Just my personal view.
