Hi folks, I am having problems with bluetooth and my K-3 III.
I have the latest version of Image Sync on my Samsung S11 (latest Android update) and latest firmware on the camera.
I successfully paired the camera to the phone using Bluetooth.I had "Automatic Bluetooth Connection" enabled in the settings of image sync. I tested that it was storing the GPS data for photos and it was.
Turned off the camera and an hour later went back to it. I went back to image sync on the phone and turned on the camera. The phone and the camera will no longer connect using Bluetooth.
Turned phone on and off again, nothing. Turned camera off and on again, nothing.
So, deleted the pairing information on both devices and then went through the pairing procedure again - which worked.
Tested it and everything was fine.
Turned the camera and image sync off again. Went back to image sync, gave it a minute or two then turned on the camera. Again, no connection between the camera and the phone would establish. This time after about 3 minutes of attempting to connect, image sync asked if I wanted to try and pair the devices again.
Any clue from anybody what is going on? Samsung is notorious for disabling app functions for battery saving reasons, so will investigate that - meanwhile any help gratefully received
