Originally posted by sebberry
If a zoom lens needs different AF adjustments at different focal lengths
You also have to consider the distance from your subject as this can also require different AF adjustments. Sometimes there are profiles that manufactures use to correct for this, but it is a generic profile that is not specific to a lens and tolerances in lens production can change how AF varies over the range you are using it.
You can also have focus shift while using different ƒ stops so this is another variable you may also want to consider and select your correction for your most used settings.
With some lens manufactures one can profile your own lens for different working distances and zoom range via a dock. this can be very handy for many of the larger zoom and would recommend this if focus is critical for your use
