Originally posted by snappyhoffy
I appreciate the work that is going on with this. Is there a component of this software that would simpy allow you to connect the camera to your computer via wi-fi (or bluetooth) to transfer files from either of the SD Cards? I wasn,t after a tethering solution just a means of connecting to the camera for downloads.
Yes! In fact I try the software in the beginning to connect the camera to the PC and download the images thru WIFI. That piece is pretty much stable now.
In my workflow this is not too efficient because I use Lightroom so, once the files has been moved I still need to "import" the files into the catalog. Unfortunately there is not, at the moment, a "Adobe Plugin version" of this software.
Danilo
