Originally posted by bobbotron Bit of a dark horse given the mixed feedback on autofocus, have to imagine the better AF of the K3iii would help it out?
I tried the Sigma 18-35mm f/1.8 ART on a number of camera bodies: from the K10-K7-K5IIs-K3II-K1 and KP, all cameras experienced varying degrees of inconsistent AF lock results with my copy of the lens. The K-1 and KP would hunt more but eventually would lock focus (the old K10 would just give up after two cycles and typically misfocus on both attempts) though the gap between infinity and 1.8m was always problematic. So it is possible the K3III may be better, as always YMMV. No camera I have used this lens on could obtain 90% reliable AF locks*, even under controlled conditions.
It is with many reservations I'd suggest getting this lens, but I assume you are reasonably comfortable with manual focusing: If you do get the 18-35mm f/1.8 ART get it with the lens dock, as in camera AF calibrations with 3rd party lenses won't be as accurate as dedicated calibration solutions.
AFAIK there isn't any firmware that expressly addresses the inconsistencies with AF for this particular lens.
*Tested with Datacolor Spyderlenscal, focused with Phase AF, tested 10 times each with the lens set to either minimum or ∞ focus, live view contrast AF was more accurate, but slower especially when starting from MFD.
