Originally posted by c.a.m @Kobie, based on your experience, what is your view on the following statement from the K-3 Mark III Special Site (Challengers):
Image tracking performance The essential feature of a flagship model | Challengers | PENTAX K-3 Mark III | RICOH IMAGING "The camera also features a new RGB-Ir AE sensor with around 307,000 pixels, in comparison to the RGB sensor with around 86,000 pixels installed on previous models. Thanks to the sensor’s improved resolving power, the camera automatically selects the optimum focus point, after the AE sensor detects the subject’s face and pupils."
I think you're correct about the Operating Manual, and the distinction between OVF and LV 'subject' recognition. There's scant insight into the specific operation of the subject detection/recognition functionality.
- Craig
Okay, here we go lol....
Pentax cameras can AE for faces from the RGB sensor but that's not regarding AF.
My thoughts on the K-3 III capabilities is that the new RGBir sensor is used for exposure but due to the ir element it can now more accurately find and track faces but then sends the position to the actual AF sensor. Coupled with the deep learning built into the software once it detects a face, it will try to find an eye. However, it is not actual "Face Detection" per se or there would be an option in OVF shooting to specifically turn on/off Face Detection. Subject recognition is basically...
1) Analyze the scene>Scan through programmed subjects to recognize>I see a flower>check database>found it=Set focus to track that subject.
2) Starts the same as above but this time... >I see the shape of a face>scan database for face positions>found them>Now look for eyes that go with face position>Not found>default to highest contrast/closest phase match within AF area.
3) Same as above but... Found eye>follow position of that subject (eye).
4) Same as above but.... Check database for subjects>None found>Default to highest contrast/closest phase match in AF area.
In the way that it works, if you want to stretch it out a bit, yes it does do face detect, but ONLY to find an eye. If it doesn't find an eye, it will default to regular AF parameters without recognizing the subject at all.
When I tested it, I'd get a shoulder, an eyebrow, my nose as primary focus points when it couldn't nail my eye even though my whole face was in the frame.
In Live View Face Detect puts an entire box over the face. OVF does not. It will do a few points seemingly randomized in AF.S comparing it to the Face Detect from Live View.
