Hello,
I must admit I´ve the same problem with myK3III….and – as written in a parallel thread - manly with the 16-50 PLM.
But all the other lenses show this inconsistent with OTHER AF than Spot/Centre Focus in AF-S.
In AF-C it´s working more or less good.Very curious since this is more complex.
But as @Eric Seavey I better choose AF-S for portraits since the movement (when “things” are slow and shutter speed high enough) because the AF-C really “Search” for movement and seems “disappointed” and fail often when things are not moving.
So all new features/grids/zones/auto-topics are not really reliable in my portrait work.
And now the news: I get my K3 III back from repair store (4 Weeks in repair!). On a small paper they wrote “Calibration” ….not more (I´m not a big fan of this very small communication of this service center here in Germany – but this is a different story).
But nothing changes this.
And since I read so much fantastic reviews of the new AF of the K3III I´m a little bit disappointed.
I often think I´m the only person with a Pentax who don´t use it for landscape an birds when I look at sample photos in the forum here ;-) But I think that is more or less the “problem” that it is not so easy or common to show friends/wife/children without their permission. So thanks to Eric Seavey: I´m not feeling alone.
Regarding my more or less parallel/similar problem written in the AF-S Select thread: When using outer AF points the failure is massive frontfocus, too!
And as well using this Zone AF: the points are showing that they find something (as in the portrait above I would say the middle of the body)…..but why is it totally out of focus? Ok the shutter was very slow as mentioned by another member, there might be some blur from movement….but you can see clearly at the ground the front focus. The leafs get sharper in front of the women (and I think it was only ONE example, and as me, he has a lot of more, otherwise he would not ask this)
So….I´m right before sending the 16-50PLMto services as well. Because it shows this very massive. I attached it for better comparison on my K3II. It´s not really good comparable, since the AF field is limited. But the front focus also behave when choosing outer AF-fields with really good contrast confirmation.
I´m now doing old fashion AF Spot/Center halfpressed and recompose…. But – as mentioned above: that’s not what I paid for.
---------- Post added 12-01-21 at 06:49 AM ----------
And I forget: this mentioned "5-point region (In think is called Select S)" doesn't´t work for me as well.
When I pout this "cross" on a face and half press, the cross changed only to the center point...ok...so far...so good.
But the face is not in focus!
When I use the normal Select with one AF filed, and have luck with an outer region: it´s better.
I don´t use this mode.
I thought in the beginning, that this works better with subject recognition, when there is really bad contrast or better nor edges ON ONE POINT...so It could help with the neighbor AF points...but not with faces :-(
or not with my camera :-(
