Originally posted by LaurentD It is not accurate, as I have also used my Pentax 16-85mm with astrotracer type 3, and NOT at 16 or 85 mm: it worked perfectly.
Pentax should reformulate their lenses recommendations, otherwise people will fear to use astrotracer type 3.
In theory, AstroTracer do not work well if the lens has distortion. Most zooms have distortion att the wide end. In practice, this problem might be acceptable for the user. But, Pentax do not agree.
---------- Post added 01-03-23 at 08:27 AM ----------
Actually AstroTracer is a so so solution. I know that many uses it and are satisfied. More power to them. But, the star movements is not even in the sensor plane. It is not possible to make a perfect compensation. And, this is not only theory. I have looked at lots of AstroTracer made images. They, more often than not, have varying star streaks all over the image. Sure, much better than without, but maybe not so good as we are lead to believe. And this is not a quality and precision thing. It is the method that is flawed.
The right solution is to rotate the camera around an axis parrallell to the earth rotation axis. Then the stars do not move and all stars in the field are sharp points. Independent of lens used.
