Originally posted by Tjompen1968 The manual says "By using interval shooting together, it is possible to perform the main exposure multiple times for each test shooting."
I haven't tested interval shooting yet, that's something for next time. I was pressing the shutter button manually for each exposure (which means that there were 7 test exposures total).
Probably 4 shots per one calibration would have been OK in this case. After a few minutes the camera needs to be re-positioned anyway unless I'm willing to crop more, GPS or no-GPS. That's the limitation of Astrotracer in general.
Originally posted by slartibartfast01 I wonder how this compares to the standard Astrotracer. Does it actually have better performance?
At least in this example where all stars move relatively uniformly in the frame, from my experience I say it's as good as the standard Astrotracer with GPS/compass/tilt-meter as far as the end result is concerned. Better in that I didn't have to worry about calibration.
OTOH, once you do the calibration right for standard Astrotracer, you can point the camera anywhere you want in the sky without re-calibrating. That's not the case for Type 3, but that's a VERY small price because Type 3 "calibration" is relatively short (the manual says 30-50 sec) and completely automatic.
But Type 3 "calibration" could fail (or it could pass but the result could be blurry) under some conditions according to the manual, i.e.
- anything other than the stars are in the frame,
- you cannot get enough exposure for stars because of heavy light pollution etc.,
- focus is too soft,
- there's camera vibration.
They recommend GPS for starscape (landscape with stars) with wide angle lenses. Also there are some restrictions about the lenses.
- No fisheye.
- You can only use the wide and tele end of zoom lenses. The only lenses where the entire zoom range can be used are:
- HD PENTAX-DA 55-300mmF4.5-6.3ED PLM WR RE
- HD PENTAX-DA* 11-18mmF2.8ED DC AW
- HD PENTAX-DA* 16-50mmF2.8ED PLM AW
I don't know what the last one about zoom range really means. The only Pentax K-mount zoom I have is 55-300 PLM, but I'll use my Sigma 16-55mm zoom to see what happens for in-between focal length.
