Originally posted by HanSch Is there any way to overrule the automatically set focal length? I can't find anything in the menu or in the camera manual. Same problem with the K5, by the way.
There's nothing that can be done about it … the camera either gets the information from the lens and uses that or it does everything manually.
If your converter doesn't "intercept and translate" the signal from the lens, or at least notify the camera of it's presence, as the Pentax item does, then the camera is simply unaware of it's existence.
So, although the final Shake Reduction may be less than optimum, it should still give at least a stop or so of correction, so just take that little bit more care when using the converter.
FWIW, in my experience with my lenses, the 26M-pixel image from the K-3iii will often give a cropped image of similar quality to that obtained through a converter with less cropping. This, of course, may simply reflect the possible lower quality of my Kenko converters or the lower resolution of my non-OEM lenses
The K-5 and cameras of similar or less resolution can seem to benefit from the use of a converter to a greater degree … again, in my experience.
