Originally posted by house I agree completely with your analysis including that you have to push extreme amounts to get there.
See? We
do agree on some things
Actually, more than you probably realise
Originally posted by house Pushed one of the darkest files from very dark to completely blown out without introducing any cast what so ever. A small amount of noise in the darkest parts was all that happened. This was Rawtherapee that currenly uses the embedded colour matrix so it's not even special on that front, someone with adobe software should try a 10 ev push and tell us what happens.
OK... so I can get the magenta tint in recovered shadows...
sort of... in
one of the under-exposure test files (many thanks to @ThorSanchez for these).
In Lightroom 6 (the latest version I have), I load the file and set the profile to "Embedded":
I bring up the exposure by +5 EV:
Looks good at this size. Let's zoom in 1:1 in the dark, top right corner:
Still looks OK at this size of reproduction. Let's try bringing up the shadows... and at +40 I start to see some magenta tint:
Taking the shadows all the way up to +100, I definitely see some magenta:
Here's the thing, though. If you look closely, the distribution of the magenta isn't even. I think what we're seeing is boosted effects of the image accelerator's colour noise reduction. It's a very clever bit of hardware / software imaging pipeline technology, but one of the things I
don't like about it is that it tends to leave blotches of colour - typically magenta and green, but mostly magenta. You can see this if you look at K-1II high ISO raw files with dark areas, and the reason I don't like it is that it's harder to remove these blotches than regular randomly-distributed colour noise. It's less obvious in the KP, strangely. Anyway, I think this is what we're seeing...
... but really... +5 EV exposure boost, and +40 shadow boost on top of that before you see anything... and even then, it's not a problem. At +100 shadow boost on top of the exposure push, it might be considered unacceptable, but who does this in reality? Youtube testers, perhaps...
I think K-3III owners can rest easy... and, as they'd say on the Eurovision song contest: "
Cameraville - no points... nul points... keine Pünkte!"
