Originally posted by sebberry Any thoughts on why the camera just can't sort itself out?
I'll suggest several possible causes.
The environmental conditions were challenging, with overcast sky, low contrast and light fog. Furthermore, the Canada Goose presented a relatively low-contrast target against the water. A mature Canada Goose has a head-to-tail length of 80-100 cm and it has a large body, so it's possible that the AF points were looking entirely at low-contrast patches on the bird; the phase-detection AF might have been struggling. Using the SEL-3 Expanded Area (M) mode, the 'helper' AF points could have been looking at other similar patches on the bird or on the surrounding water.
Regarding depth of field, an aperture of f/2.8 could have been okay depending on the distance to the target. It looks like the bird landed near the shore, and we might estimate that you were fairly close. A distance of 5 meters, FL 100mm, and f/2.8 presents a DoF of only plus/minus 13 cm in front of or behind the focal plane -- not a lot of wiggle room. At a target distance of 10 meters, the DoF would have been +/- 50 cm.
I also have the DA* 50-135, converted to screwdrive. It's not the fastest lens in terms of AF, but it's not terrible. However, I could believe that it might have had trouble keeping up with the camera's AF commands. I think there's a small amount of 'slop' in the gear train, by design.
- Craig
