Originally posted by Kobie 1) did you reset either the AF adjustments in the menu or reset the whole camera? Many of us have discovered that for whatever reason, it seems to be a necessity after a firmware update.
2) The update says nothing about Live View. The improvment is for AF accuracy and stability for OVF shooting only.
It is possible that there is an issue with your particular K-3 III but I would reset it first and go from there.
Sorry af.c auto through the viewfinder is 100% constant failure. Looks like someone smeared vaseline on the 15mm lens. -10 all the way to +10 doesn't fix focus. two copies of the 15mm limited neither work on my k-3iii.
FA* 50mm F/1.4 is also the same when focusing. low and to the left if something moves from right to left. i can try to photograph a huge freight train and the camera with af.c to the closest thing, the ground, and never even try to focus on a moving freight train. low and to the left. on the ground. live view. or through the viewfinder. still doesn't select auto focus points at all sometimes. firmware 1.41.
my k-3iii has become the worst thing i ever spent $2,437.00 on.
---------- Post added 03-12-22 at 08:27 PM ----------
Originally posted by repaap AF improvement in this FW is in OVF mode, not in LV. Other than that I don’t know..but this is what you can read from Ricoh page when you look at what they have improved
Sorry I should have made it clear that focusing my 15mm limited lens, both copies, through the viewfinder of my k-3iii result in images that look like someone has smeared vaseline all over the lens. someone said increase you depth of field. lol. i can use my fujifilm x100v and shoot at f2.2 with a softening filter on the lens and it is still sharper and has more depth of field than anything either of my 15mm limited lenses can do. i have used a lens calibration chart and tried from -10 all the way to +10 on both lenses and neither did anything.
the 15mm lenses work fine on my KP, K3, and k5-II, besides the known soft in the corner issues. the lenses work in af.c on all 3 of those cameras. through the viewfinder.
i didn't see any improvements in auto focus on my k-3iii solely using the viewfinder a couple of days after my original reply.
the camera still focuses on the closest object and if the focal point is in between the huge gaps in the auto focus points it won't even select an auto focus point.
