Show Printable Version 112 Likes Search this Thread
05-10-2022, 07:45 AM - 7 Likes   #46
I have a lot more hours now under my belt with camera, 150-450, and continuous focus. After this past weekend's BiF shots I think I'm beginning to get a handle on it, but still a work in progress.
When a bird/critter is at rest focus is essentially a non-issue. Pick up the camera, back-button focus and shutter. Takes just a couple of seconds and focus is almost always spot-on, emphasis "almost always" with cluttered background and similar color tones.
Now with continuous focus I'm sure the regulars have seen my series where I concentrate on anticipating a moment when the bird takes flight or lunges for prey, or begins fights. Using TAv and small select zone I'll frame the subject and hold the focus button, snapping shutter as soon as movement is obvious. For lateral and close-in that works very well, not too challenging anymore, and I'm very comfortable that it works. Same even if a flying bird is moving at an angle to me in a clear sky. But I've had issues with birds moving towards or away from me, combined with more cluttered backgrounds, where the focus will shift to a background element before righting itself (if it's going to) after two or three frames.
I think I'm leaning now towards using shorter bursts, three shots was my go-to Saturday and Sunday, then refocusing before continuing with the tracking and more short bursts. That seemed to result in more keepers than just holding the focus and running off a long continuous burst. There were times the camera never did catch back up or took too many frames to do so, and pausing and resetting focus appeared to work better.
Of course with a diving eagle or osprey going for a fish those short bursts aren't ideal. I got some great nicely focused shots from diving through hitting the water on Sunday, but as soon as he splashed down I lost focus and didn't reestablish for a few frames after he got back in the air. That was with continually holding the focus button and yes after I think four frames later it caught back up. Water action seems to give the camera problems. When I have another opportunity I'm going to try stopping at the point the bird hits the water to reset focus and then restart the bursts to see it that's more successful. And BTW, medium burst seems to work well. Faster might work even better. Or not. But then there's not much working time before the buffer fills. That said I may also give fast burst a try if I'm limiting myself to 3-5 shots before pausing a second or two to refocus anyway.
By the way, owning the K3III and a pro-quality long lens has presented me with challenges I'd never accepted with my other cameras. I've so rarely used continuous shooting up until a few weeks ago it wasn't at all a consideration for me. One shot at a time, focus/shutter/focus/shutter. Yup I got fast with it too, but not fast enough to capture a heron first stalking then snatching a minnow from the water and lifting it up to eat, or the launch and flight of a Great Blue from his perch.
I bought the 150-450 in mid-March this year, and since then have put in roughly 40 hours shooting with it in combo with the K3III and most of the time in continuous. Gosh, it's been a learning experience. It's taken several weekends of at-dawn hikes thru the marshes and preserves to get comfortable with it, and another several to get to the point I'm understanding it. I feel I'm now progressing past a few somewhat lucky shots to expectations of success. I'm moving forward. My joy found in wildlife photography is restored after a couple of years of lost interest in it.
05-12-2022, 01:39 PM - 3 Likes   #47
Larrymc's Avatar
QuoteOriginally posted by gatorguy Quote
I use the same technique and it works well. Several years ago I was on another photography forum, UHH, and was reading a discussion about birds in flight and focus techniques. A photographer who was a member there who had some excellent BIF images was disclosing his technique he uses with his Nikon DSLRs. He calls it "bumping the focus" and it is essentially the same technique you are using, use BBF and short bursts then release the focus then reacquire with another series of short bursts. I tried it with my K-3 Mk I and discovered it worked pretty well with the supposedly not so accurate continuous AF on the K-3 Mk I.
Larry
05-12-2022, 03:35 PM   #48
QuoteOriginally posted by Larrymc Quote
Larry
I appreciate the feedback. Makes me a little more confident this is the way to go, so come Sunday I'll be trying it out again.
05-12-2022, 08:19 PM - 1 Like   #49
Larrymc's Avatar
Holding the back button in (or for that matter the shutter button) and waiting for the continuous A/F tracking system to reacquire focus can be at best hit or miss with a busy background. I've found that "bumping the focus" is much more reliable. Good luck!
05-12-2022, 10:04 PM - 1 Like   #50
cmohr's Avatar
I've been doing a lot of BIF photos myself recently, I have found that my lastest setting seem far better, AF-C using expanded area, and centre select, once it locks on, it's great, I also found that Focus Hold on Maximum setting is really good, I did originally have it set to low or off, thinking, that it would be the quickest reaction to a moving object, but, in reality, it is actually reacting too fast, and loosing lock on the subject when panning and following a bird in flight, with the Max setting, I can follow a bird and keep lock on it for longer.
( This comes from panning and following birds across the sky, just the movement of panning to keep the bird in frame is a bit of a double up of movement for the AF to cope with. I would often look at my pics, and when I would zoom in on them, and jump to the focus point, it was always behind, or beside the bird, with the Max Hold setting, the focus point is ON the bird and I am getting far more keepers.)
I always try to keep my burst rate down, I have actually now set to medium rate, not the 12 frames.
cmohr
05-13-2022, 06:37 AM - 1 Like   #51
Larrymc's Avatar
QuoteOriginally posted by cmohr Quote
cmohr
Thanks for your information. Which size expanded area (there are three selectable) ExS, ExM or ExL? Does Focus Hold also work for BIF coming toward you or going away from you or at various angles? You mentioned Center Select is that another setting that you use instead of the Expanded Area? I'm not disputing what you are saying, I'm just trying to get a better understanding of everything as Ricoh/Pentax is not very helpful with all of this.
05-15-2022, 05:23 AM - 2 Likes   #52
cmohr's Avatar
Expanded L. I use Centre select, so as I know exactly what has been chosen, as the focus point, the camera can then follow focus around the entire AF range. At 12 frames a second, this is about 1.5 seconds of shooting.
05-15-2022, 06:48 AM   #53
cmohr's Avatar
Honestly, my favourite pic,, is 3518.
05-15-2022, 08:39 AM   #54
Mikesul's Avatar
That is a great series. It both demonstrates the camera's capabilities and is also a fascinating bit of life.
05-15-2022, 07:53 PM   #55
Larrymc's Avatar
Nice series of shots!
05-16-2022, 06:31 PM - 3 Likes   #56
Be sure to read the expanded explanation of the K3III's AF system and recommended settings on the Homepage! Great article from Kobie.
Pentax K-3 Mark III Continuous Autofocus Demystified - Articles and Tips | PentaxForums.com
06-28-2022, 02:28 PM   #57
Really great series of pictures! You are lucky that the birds you find are large. I only have robins and bluetits around which are much harder to lock on to....
07-21-2022, 09:17 AM - 2 Likes   #58
simon_199's Avatar
I've read some material on the forums and watched some youtube videos to view some opinion on the "viewfinder eye-af". I think I understand how it's supposed to work but I'm a bit confused by the lack of information. We all know it's customary for Pentax to poorly document and market some great features that remain somewhat hidden, buried in the menus, not clearly explained, etc.
However, this solution is something that could bring in the Pentax DSLR world one of the main selling point for ML cameras, that is make your life easier for portraits with large aperture lenses, so I expected it to be one of the main selling points from a marketing point of view. But the fact that there was the need for youtubers and pentax users to almost reverse engineer how it is supposed to be enabled in camera suggests otherwise. This is why I suspect that real-world performance is not good enough to strongly market this feature and it was implemented in a sort of experimental, "beta" state. Is this really the case ? I have realistic expectations and don't expect a DSLR to rival best-in-class on-sensor AF implementations, but does it effectively improve the keeper rate for portraiture ?
I don't do portraits professionally, so my skills could easily be the limiting factor, but with my K-3 it's really difficult to use anything other than the center point AF. All other points are just not reliable enough. Hence one has to focus and recompose, which often fails with thin DoF and is quite cumbersome so that I often just adjust focus manually and hope for the best.
Does the improved AF coverage with denser points, coupled with basic eye recognition of the K3-iii make a tangible difference ?
I'm very curious about this technology and I wonder why it is so poorly documented, almost never mentioned in reviews (for what reviews are worth...).
07-21-2022, 12:38 PM   #59
QuoteOriginally posted by simon_199 Quote
It's not just Pentax literature that is missing information. I just purchased a Nikon D500 and the same goes for it. Right now, I'm trying to figure out how to use HSS flash mode and struggling with both my Pentax and Nikon cameras as I see no difference to not using the flash over the standard sync speed.
I really hope that Pentax will come out with some longer lenses. Improvement in AF, burst rate/frame buffer performance and longer lenses is all that needs to be done for the Pentax system. If only manufacturers like Sigma and Tamron would take up an interest again to make lenses for Pentax mount that would be unreal.
With such poor AF performance on the K1 ii, I am forced to limit its use to landscape and fixed macro only (and Astro but that's another story). Any type of shooting where I need the incredible imaging capability but can get away with using MF and can spend 5 or 10 minutes preparing the shot.
The D500 on the other hand is a speed demon; currently I have two lenses for that, the Nikkor 18-300mm (walkabout) and the Sigma 105mm macro. Now I am able to get countless keepers and amazing shots which I would have other wise missed entirely using the K1. My next lens hopefully will be the Sigma 60-600mm for wildlife as I find even the 300mm end (or 450mm in APS-C terms) too short.
After spending a month with the K1 and FA*300 trying to shoot birds, foxes, squirrels and planes, the only thing that actually came out ok was the larger planes. It was such a shame!!! I also find my Pentax brand lenses to be a little soft too, they are sharp but not clinical. They definitely don't have the same razor edge performance as the Korean made brand lenses like Irix and Samyang.
Of course these are only my findings and my taste in imagery. Everyone is different and looks for different things.
07-22-2022, 05:09 AM - 2 Likes   #60
QuoteOriginally posted by kayasaman Quote
Your experience with your old K1 is not germane to the performance of the K3III. Your K1 was built with landscape shooters in mind, and for that genre it's an amazingly effective camera 5 years later that still holds its own against most current flagship mirrorless cameras. Had you tried the newer Pentax crop camera designed for action you would have an entirely different opinion of Pentax capabilities and likely referred to the K3III as a speed-demon that nails the shot far more often than not.
As for the sharpness of your *300 on your K1 I suspect you had it mis-calibrated. IIRC you had questions about how to do a fine-focus adjustment on it, and perhaps never did understand how to do it properly. Star lenses are highly regarded even by photographers using other systems. For example, out at a photo shoot another photog noticed I was using Pentax and told me to try this amazing lens he had in the bag for his A7II: A Pentax *200 adapted for his camera. Said it was the best outdoor portraiture lens he owned, preferred over his Sony-branded 70-200, and rendered so beautifully on his mirrorless. I did graciously accept it for a few scenes, at the same time telling him I had one at home. Yup, great Pentax glass.
af, aps-c, camera, dslr, focus, image, k-3 iii, k-3 mark 3, scene, settings, subject, subjects, system, zone
Nature Perfect Stand-outs eaglem Post Your Photos! 12 02-02-2020 04:17 AM
Macro The Ins & Outs of a ...... eaglem Post Your Photos! 4 08-13-2014 05:48 PM
Photokina 2012 Interview with Pentax: Post your shout-outs and comments for Pentax! Adam Pentax News and Rumors 103 09-19-2012 07:39 AM
log outs newarts Troubleshooting and Beginner Help 4 08-22-2011 03:43 PM
Avoiding mid-day blow outs... Bob Wallace Pentax DSLR Discussion 8 10-03-2006 03:07 PM
All times are GMT -7. The time now is 09:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
