Originally posted by hcc Apologies if the query is trivial or has been discussed elsewhere. I search the K-3iii discussions without success.
Can the Status Screen be OFF all the time on the K-3iii?
In particular, when using the OVF, can we switch off completely the back screen?
Thank you in advance for the advice.
No problem … just press the
Info button a sufficient number of times to deactivate the screen, then press it once for Control Panel or twice for the Status screen … press once more for off
You may also need to de-activate the Eye Sensor, Menu C4 - Eye Sensor -set to Off, Off and Low.
I work like this with all my Pentax DSLRs … saves battery
