Thank you everyone so far! So for size it sounds like DNG files may only be a bit bigger than my current ones, although according to the manual they could be twice the size. I wonder if there's a compression option for DNG and/or PEF that accounts for the size differences that people are seeing, and especially vs what the manual says? I'll have a look through the options when I get the camera.
I really appreciate the comment that at first when the camera came out some people went overboard with card speed and have found it's not strictly necessary. I read a bunch of early threads and I was hoping to hear an update exactly like that -- thank you!
For the speed, I'm still a bit confused: V30 is only for UHS I, I believe, from what I just googled after reading the responses here: "V60 and V90 are used in UHS-II mode or faster" from
Speed Class | SD Association . So given that the K3 II has a UHS II slot, I should get a > V30 card?
Or am I misunderstanding? I'm definitely confused on this point
I get the idea of buying two of the same cards for sure -- if I can find a card that's sufficient to max out performance but not terribly expensive then that absolutely makes sense.
All of the Sandisk UHS II cards that I can find seem to be V90. They're also super expensive. So maybe I want to look for a UHS II V60 card? I've used Sandisk forever and it's always been good to me, so I'm a little reluctant to switch out. I see a Sony Tough UHS II V60 -- maybe that's a better choice?
Sony SF-M Tough 128GB UHS-II SD Memory Card | Best Buy Canada
Thank you again everyone!
