05-24-2022, 10:48 PM   #16
Spock's Avatar
QuoteOriginally posted by cdw2000 Quote
I am an electrical engineer. The third terminal is marked "T" for temperature. The batteries contain an embedded temperature sensor. For rapid charging, the charger uses the temperature data (along with the charging current) to help determine when the battery has reached full charge and to ensure it doesn't overheat during the charge cycle.
What is the 4th pin for as used in some newer batteries and the Pentax K-BC90H charger?
05-25-2022, 01:48 AM   #17
QuoteOriginally posted by Spock Quote
T: A resistor, 10kohm, probably temperature dependant between T and -
the fourth terminal could be the middle connection between the two cells in the battery. But I am only guessing here...... The battery have some internal electronics to make sure the cells are balanced. But they can only handle currents up to a certain level. If you want to quick charge batteries, the charger itself could make sure the cells are balanced and my guess is that the 4th connection is for this purpose.
05-29-2022, 02:12 PM   #18
angerdan's Avatar
QuoteOriginally posted by SpotmaticGuy Quote
Hi, I just took delivery of my K3 III and my first new Pentax in about a decade. I'd like to get an auxiliary battery charger, one that plugs into a wall socket and that can charge a standard battery for the K3. Any suggestions? Thanks!
I like to recommend this charging times comparision table:
New Ricoh Charger - Page 3 - PentaxForums.com
05-29-2022, 02:28 PM   #19
QuoteOriginally posted by angerdan Quote
FYI,
Your last link isn't good, going to a German site.
05-29-2022, 02:50 PM   #20
angerdan's Avatar
QuoteOriginally posted by gatorguy Quote
FYI,
Thx, i replaced it with the backside image of the charger.
05-29-2022, 09:29 PM   #21
Zafar Iqbal's Avatar
I've had 6 of these for some years and been happy with them: https://pts-trading.de/en/patona-synchron-usb-charger-f.-pentax-d-li90-d-li90-with-lcd-3187
Biggest downside is the battery plate, which over time can get deformed due to heat. They can be temporarily fixed by unscrewing bottom plate and straightening it - and in worst case, replace them entirely. I've so far straightened some recently, but not replaced any yet.
05-30-2022, 07:18 AM   #22
Reboot before calling IT
madison_wi_gal's Avatar
I got this, works fine for K-3 III (and K-01) batteries
https://www.bhphotovideo.com/c/product/640555-REG/Pentax_39835_K_BC90_Batter...981&
05-30-2022, 10:26 AM   #23
angerdan's Avatar
The new USB powered BC77 charger is 4 times faster than the old BC90.
06-02-2022, 03:35 PM   #24
Just1MoreDave's Avatar
I just got the D-BC177 Travel Charger. I have a couple of the old BC90s so I'm good for plug-in charging and I don't need speed. I have a cheap DLi90 charger with a micro USB cord, Kastar brand, but it only works now if you wiggle the cord just right. Inevitably I'll get it working and it stops when I look away, not good for charging. The D-BC177 Travel Charger has USB-C so it's the wave of the future. What was not clear to me was the required voltage input. It looks like it will still charge connected to a 5V 2A source. I'm sure this is a slow charge, but when actually traveling, I'm likely to plug into an unspecified USB port on a hotel lamp or airport chair or a rental car. I don't want to worry about the twenty different USB connectors and permutations. It seems like the D-BC177 Travel Charger will cover my needs.
06-10-2022, 09:28 AM   #25
QuoteOriginally posted by kkoether Quote
The new D-BC177 can use the usb cable and plug that comes with the K-3 III.
That's useful information. I'll be leaving for a few days on a little photo expedition, and that should give me a better idea of what I'll need. I'm inclined to go with the D-BC177, but I'm unsure about a more powerful battery. The Pentax battery is 1800 mah (doing that from memory) and I've seen some batteries rated at 2300. Might there be a problem with higher-rated batteries? Thanks!
06-10-2022, 12:19 PM - 1 Like   #26
UncleVanya's Avatar
Most third party batteries have inflated mah figures. I’ve never found any that outlast the original. Some are close to equal, none are better.
aps-c, batteries, battery, charger, dslr, iii, k-3 iii, k-3 mark 3, k3, k3 iii battery, options, question, suggestions, suggestions for k3, temperature, thanks
For Sale - Sold: Pentax K-3 body (low shutter count), battery grip and battery charger DAM4Pentax Sold Items 3 04-07-2022 12:16 AM
What battery charger is recommended for the K3iii battery? clickclack Pentax K-3 III 26 06-01-2021 09:31 AM
Comparison K3 III versus Sony A7 III bwgv001 Pentax DSLR Discussion 51 04-30-2021 01:20 PM
All times are GMT -7. The time now is 01:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
