Originally posted by Spock What is the 4th pin for as used in some newer batteries and the Pentax K-BC90H charger?
T: A resistor, 10kohm, probably temperature dependant between T and -
the fourth terminal could be the middle connection between the two cells in the battery. But I am only guessing here...... The battery have some internal electronics to make sure the cells are balanced. But they can only handle currents up to a certain level. If you want to quick charge batteries, the charger itself could make sure the cells are balanced and my guess is that the 4th connection is for this purpose.
