Originally posted by Lloyd_Christmas A lot of online reviews, like the one posted above from DPreview, used the 16-85 lens. They were not impressed with the continuous AF performance.
Good point about the DA 16-85 lens. I guess they use whatever lens is made available to them.
To me, the DPReview TV guy in the above video was quite pleased with the continuous AF performance. For example:
"Both cameras had a very good hit rate and both cameras missed a few frames, but the D500 consistently had a higher hit rate."
"The K-3 Mark III [autofocus] seems vastly improved over other Pentax cameras."
"It had a very good hit rate, did a great job, shoots incredibly quickly as well."
"Overall, I was really happy with the improvements of autofocus speed."
However, the reviewer was not as impressed with the 'buffer performance' of the K-3 Mark III, compared to the D500. In particular, they found that the camera's buffer filled after about 25 shots, which they think would be limiting in some contexts where sustained shooting is desired. The relatively slow buffer-clearing speed (i.e., memory-card writing) was also mentioned.
A PLM lens, such as the new DA* 16-50, would probably enhance the AF performance, but wouldn't help the buffer performance. Regardless, I'm not aware of any measured tests that have compared the buffering of the K-3 III and D500 quantitatively under identical shooting conditions. Intuitively, however, one would think that deeper buffers and faster writing to memory cards would be beneficial in general.
As mentioned in an earlier post, credible comparisons between the AF of the two cameras are scarce. It's even hard to find
qualitative comparisons which address the end result or outcome: Did the photographer have a successful photo shoot?
- Craig
