Show Printable Version 10 Likes Search this Thread
07-20-2022, 03:18 PM   #16
QuoteOriginally posted by kypfer Quote
Mine contains a K-3_III sub-directory with a 14.3kb FILES.DAT in it … nothing else.
That file was last updated at the same time as the last image file was created, though it was initially created about 14 months ago, shortly after I bought the camera.
As you might have guessed, the card hasn't been re-formatted in that whole time, much as the cards in my other cameras never get re-formatted!
If you have a spare SD card lying around you could try formatting it on a PC then see if the Pentax folder is created when the card is inserted in the camera.
07-20-2022, 08:16 PM   #17
Larrymc's Avatar
You have a question in front if you please answer it.
A recap: How many kb is the folder in question?
I just reformatted my SD card after I downloaded today's DNG files and the file size is 3.2 kb. I reformat after every download and have not noticed anything out of the ordinary happening. All of this sounds like a lot of worry about nothing, but to each his own.
07-21-2022, 12:06 AM   #18
QuoteOriginally posted by slartibartfast01 Quote
OK … done that … insert a PC-formatted card into the camera and the DCIM, PENTAX and PENTAX/K-3-III folders are created immediately, without switching the camera on. This'll be the flicker of the orange "Card Access Lamp" when the card is inserted
The FILES.DAT isn't created until a picture is taken … in this case, with the first lens to hand, a pre-set manual 28mm, the file is 88 bytes.
If anyone wants more detail than that they can create their own FILES.DAT files with different lenses and compare the contents thereof (which aren't in text or other recognisable format).
Enjoy
07-21-2022, 04:27 AM - 2 Likes   #19
Kobie's Avatar
I would like to see any evidence of the camera using data from the sd card for anything beyond sd card operations and info like remaining space.
Okay, here you go.
---------- Post added 07-21-22 at 07:28 AM ----------
QuoteOriginally posted by Larrymc Quote
Please point us to the information supplied by Kobie relating to the potential value of data collected and stored in the PENTAX folder that relates to AI learning. I'm not aware of any at all.
As you wish...
07-21-2022, 07:21 AM   #20
QuoteOriginally posted by Kobie Quote
Okay, here you go.
https://youtu.be/2UBJ8LGbUcM
As you wish...
Thanks Kobie. This is the video I was searching for.
Hope your AC problem is fixed and things are cooler now!
07-21-2022, 08:22 AM   #21
Kobie's Avatar
QuoteOriginally posted by reallybothered Quote
Thanks! It's all cool now
07-21-2022, 10:50 AM   #22
UncleVanya's Avatar
I watched the video. I don’t see anywhere that suggested that the contents of the Pentax folder were attributed to 1) performance of the subject identification and tracking or 2) changing as a result of using the camera. A simple test might be to shoot a lot of subjects like birds in the auto scene mode and copy the sd card then format an identical card and do multiple tests to see if the card with the longer experience did anything different. Then take the two folders and swap them 1 for 1 but leave everything else alone. Having worked with ai experts myself I can’t see the camera doing any deep learning that persists from one session to another - I can see it leveraging ai to use the heuristic rules built by analysis and baked into the camera firmware. That’s different than using traditional subject recognition models in that these would use learning during model training which requires feedback from someone about the accuracy of the results.
07-21-2022, 11:39 AM   #23
Kobie's Avatar
The camera doesn't "learn" anything. The folder is basically a preset database driven from the camera within the firmware itself. It's pretty much "if/and" statement call outs. Why it's stored in the SD cards, I have no idea. The size of those folders will never change unless more is added via another firmware update.
07-21-2022, 01:04 PM   #24
Larrymc's Avatar
So if someone never updates their Mk III firmware they aren't getting the benefit of the additional "machine learning" provided by the firmware updates?
07-21-2022, 01:17 PM - 1 Like   #25
Kobie's Avatar
Correct.
07-21-2022, 04:12 PM - 1 Like   #26
UncleVanya's Avatar
Read post #1 of this thread. That post suggested a concern about formatting the ad cards due to possible loss of data that is used by the camera. I was asserting that nothing you said suggested there was data that accrued over time but there was a simple test to determine this.
Additionally I would point out that a lot of k3iii owners are reporting different sizes of these folders and some are t seeing the folder at all. It’s wonky. It doesn’t make sense to write this out to disk from firmware at least not to me. I’m confused as heck.
I don’t own a k3iii so I’m watching with interest.
07-21-2022, 06:15 PM   #27
R.Miller's Avatar
My Panasonic Lumix does this. It creates separate folders for different file formats for still images vs video. When I first got the Lumix I was surprised to see the extra folders after all the years with Pentax. The DAT file may just keep temporary tracking or house keeping info for them. Makes sense. It would make no sense whatsoever to put critical "learning" data on a temporary storage media.
Maybe the K3.3 is doing something similar.
Where does the camera store the photo and video files on the SD card?
07-21-2022, 06:37 PM   #28
Kobie's Avatar
QuoteOriginally posted by R.Miller Quote
The K-3 III does something different. Inside each SD card are 2 folders. One is DCIM which only has photo and video files. The other folder is PENTAX. They are separate folders in the root of the card.
07-21-2022, 07:31 PM   #29
UncleVanya's Avatar
Maybe people should save copies of these folders to compare.
07-22-2022, 10:05 AM   #30
Any chance the data is used for the Image Sync app?
aps-c, camera, card, cards, data, dslr, firmware, folder, folders, format sd card, iii, iii to format, k-3 iii, k-3 mark 3, k3 iii, lot, pentax, post, sd, time
K3 Mk.III writing to the "wrong" SD card slot oneill Pentax K-3 III 13 06-20-2021 09:21 PM
SD card Just bought an Sandisk Ultra SD XC1 64 Gig Card and comes up with error Craig Hickman Troubleshooting and Beginner Help 10 07-30-2018 11:37 PM
For Sale - Sold: Fuji F550EXR, 4GB Eye-Fi SD Card, 4GB SD Card, 2 Batt + 6BQ5 Sold Items 3 09-16-2013 08:19 PM
Crap! My new class 10 sd card run much slower than my old class 4 sd card... liukaitc Pentax Camera and Field Accessories 15 05-31-2011 01:39 PM
All times are GMT -7. The time now is 12:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
